Question about Toys
How to charge ignite falcon flyer - Toys
I have an 82 xe falcon and it wont start ive got all dashligths but no ignition its like the car has no battery in it but it was running fine yesterday
You mean your starter doesn't crank the engine? Turn your headlights on and try to start the car, do headlights get dim when you turn the key?
Jul 25, 2016 | Cars & Trucks
2003 BA FALCON XR8 260 BOSS MOTOR HAS NO SPARK FRON IGNITION COILS
Ok first things first , If your car does not start then it should have a fault code stored in it's ECM , have you checked with a scanner?
A faulty code can put you in the right direction to repair the vehicle straight away without wasting any valuable time. Each coils are controlled by ECM, check for ignition power to the coils. Do you have Injection pulse? If you do then most likely it's not a crank angle sensor or ECM issue. If the car was immobilsed then it would not crank over.
Unfortunatly you have to do more checks before moving forward. Cheers
Jan 07, 2014 | Cars & Trucks
Nano falcon English instructions
after i charge my nano falcon properly and everything seems fully operational i can't seem to get it to lift off or acknowledge anything i do with the fully charged remote. i even try the A B and C shifts and nothing is working.
Dec 25, 2013 | Audio Players & Recorders
Htc wont charge and turn on
If it won't charge then you may have a defective charger, a failed battery or a loose solder joint at the charging port. If your charger plug is fitted with a fuse then consider checking the fuse is okay by trying a new one. Also, check your charger on a friends HTC, check their charger on your HTC. It really is a process of elimination to find the issue yourself.
The HTC won't turn on because it isn't charged, until you fix charging prob it won't turn on.
May 02, 2013 | HTC Flyer 7 inch 32GB Android Tablet PC...
Broken Ignition on a ED Falcon
put a new ignition switch in the car
Jun 08, 2017 | Cars & Trucks
How to bypass immobiliser in 94 ford falcon after ignition barrel has been replaced ??
Your ford dealer visit may not be as expensive as you think, you need 2 pats keys and have them perform an ignition key code erase then they should be able to program your 2 new keys, The Ford Dealer I work at only charges 0.5hrs or approx $50.00 dollars Canadian.
Jan 12, 2012 | Cars & Trucks
Falcon ED wont start. No spark. Just replaced
check all the fuses 10 amp is pretty common same as radio fuse
Jun 07, 2010 | Ford Fairmont Cars & Trucks
Big flyer replacement pedal
Contact Radio Flyer online and request the replacement part. They confirmed the replacement within 5 hours.
Dec 30, 2009 | Radio Flyer Big Flyer
Toys Logo
52 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
