Question about Ricoh Office Equipment & Supplies
Displays c-1 on front panel and front switch is good. Rocoh FT 4522
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; On the front door there have a door actuactor may be it broken. or door switch loose.
Posted on May 23, 2009
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Front load washer door will not lock
Hello Phyllis Emmett - Do you notice any error codes displayed on the control panel or lights blinking? If so and the panel displays "DR", the door may have a defective door lock switch. However, if panel displays "DDO" either the drawer is not closing, magnet may be missing or have a defective reed switch, which you will need to contact a professional to diagnose the unit.
Sep 24, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have samsung and it displays l5
If it is E2 15 then it may be a switch error (Main Relay error) Check for stuck button switches or power button switch for sticking. May need to replace the main PBA. Verify the error and provide the model number to verify the error code specific to your model.
Aug 28, 2012 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
Wont start... the power comes on but when you push the start button it just beeps like the door is open. can you send me a diagram of the door switch and how to change it
IN order to change the door switch, you must remove the outer door spring that attaches the gasket to the front panel. Of course, disconnect the plug first. There are 2 screws that attach the switch to the front panel, if you remove them, it releases the switch and to access the switch, reach inside between the front panel and remove the 3 quick disconnects and the door switch is then removeable... Use caution when reinstalling the door seal and spring in order to avoid leaks. Good luck!!
Nov 20, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a RICOH FT 4022 copier and it displays E 5 error code. It does not allow copying. I have checked the fuser unit and its ok. What could be the problem? Do I need a reset code to solve it and where do...
The E5 code is the fuser malfunction error.
E52 fusing lamp warm up error.Possible causes thermistor open,heater lamp open,thermofuse open.
E53 fusing lamp overheat.Thermistor in shortcircuit
E55 fusing thermistor open
When service call E5 conditions occur they cannot be cleared by turning OFF/ON the power switch.To reset turn ON the main switch,turn DIP switch 101-1 ON and OFF(the DIP switch is located in rear part under main supply board).,and turn the main switch OFF and ON.
Nov 11, 2009 | Office Equipment & Supplies
Error code e-1 for Ricoh FT 4522
we don't have e-1 code but we do have e101,if my one is correct,there have few steps to follow;
1,press "clear modes"
2, press 107
3, press and hold down'clear/stop" key
4, enter 5 press start
5,enter810 press start
6, turn power off and on
Dec 11, 2008 | Office Equipment & Supplies
Ricohh 450. Error code E544 or E-5 comes up. What can I do to fix
This is a fuser error code. Sometimes it is caused by a mis-reading. Use the procedure below to reset this machine.
Press the yellow "clear modes" key then pres 1, 0, 7, then press AND HOLD the red "clear stop" key until the screen changes. After the screen changes, turn the machine off at the red switch on the front of the machine. Turn it back on.
If the code comes back you will have to call a service tech to troubleshoot and replace parts.
Nov 25, 2008 | Ricoh Aficio 450 Copier
Ricoh ft 4522
check the fuser first, it should be clean and shiny otherwise it's coming from drum area
Sep 12, 2008 | Ricoh FT5832 Copier
Ricoh FT 4427
It's an analogue photocopier, black & white.
Not worth much, but was a very popular model in its day.
If you're just after a straight forward copier, it should do the job.
Feb 25, 2008 | Office Equipment & Supplies
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
