Question about Refrigerators
Clogged defrost drain on ge adora dfss9vkbass
Freezer leaks water and freezes water on freezer floor
  • 183 Answers
SOURCE: Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Posted on Aug 23, 2007
MNTECH
  • 1543 Answers
SOURCE: GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Posted on Jan 06, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Posted on Jun 02, 2009
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
SOURCE: I have water leaking on the floor due to a clogged
You have to take everything out of the freezer side and remove back panel. There are 2 white hex screws around where the second shelf normally is. Top half (where fan is) comes off first, then bottom half comes off (it may be stuck if coils are frozen, let defrost a little). You will see stainless steel drain pan below coils. Also could be ice maker water supply or water chiller behind lower drawers on refridge side.
Posted on Aug 04, 2009
  • 67 Answers
SOURCE: ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Posted on Aug 11, 2009
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ge adora draining on floor
Possible that the defrost water drain tank is full and is overflowing. Also it can be due to leaks from the Auto-defrost cycle , the tube could be leaking or the connecting tubes are loose.
Observe the leak point and go further into tracing the case. Check the setting of the thermostat and make it to normal settings
Jan 31, 2013 | GE Adora DSS25KSTSS Stainless Steel Side...
Freezer bins keep icing up
Freezing over of freezer bins may be caused by warm moist air drawn into freezer by the ice chute door being stuck open or door seals being defective. Also if the defrost drain is clogged with sludge or ice behind the rear panel where the evaporator is located. Are you sure that model number DSS25KSTSS is the correct model number? Do you see ice forming on the floor of the freezer? I will be here to answer your questions, Thanks Sea Breeze
Leaking Refrigerators
Jan 29, 2013 | GE Adora DSS25KSTSS Stainless Steel Side...
Refrigerator ge profile model TFH27PR water leaking onto floor
Hi this problem could arise due to various reasons so lets find out what could it be the cause.
1)In the back of your freezer compartment is the drain hole. It's very common in GE for the drain to freeze up. With the drain hole plugged up, your freezer will continue to defrost the evaporator, but not the water in the drain hole. So the water builds and freezes, builds and freezes until it eventually overflows into the air diffuser for the fridge causing the leaky fridge problem."Heat Probe" that can be installed.This will prevent water from freezing up in the drain hole allowing it to drain as designed
2)Inspect the door seals and the sides of the refrigerator around the doors. If you see any beads of water or moisture, then the door seals may be failing to create an air tight seal which causes the cold air from the refrigerator to escape and form condensation around the doors. Sometimes you can solve this problem by applying a light film of gasket lubricant to the existing seals or just cleaning them of any debris with a warm soapy rag. If they still don't seal well after you apply lubricant, or clean them, you may need to replace the entire seal assembly.
3) If the water is coming from the freezer but you think that the defrost drain pipe is clear, then it may be coming from the ice maker. Check the ice maker for cracks in the unit's body or a misalignment of the water supply line. Make sure that the water supply spout in the freezer lines up with the ice maker's water supply cup.
4)Check the ice maker copper water supply line, your ice maker water filter, and the plastic ice maker water supply tube for any cracks, splits or connection leaks. If you find any leaks, remove the leaking part and obtain a replacement at the hardware store.
5)Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
6)If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Note:Switch you Refrigerators for more than 8 hours and let the frost melt fully use hair dryer and now switch on and check you are getting leak.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | GE Refrigerators
My Jenn-air refridgerator freezer section leaks water and builds up on bottom of freezer, defrosts then leaks out
sounds like you have a clogged defrost drain. when the unit self defrosts, the meltwater from the evaporator is supposed to go down a drain under evaporator, to a condensate pan underneath. when this drain gets clogged at any point, the water then drips into the freezer floor, freezes, eventually over fills the floor, and leaks onto kitchen floor. Do not try to snake out the drain, as it is plastic and usually not permanently attached, snaking can damage or dislodge the tubing, making problems worse. If you have a compressor, you can direct some compressed air into the drain to clear out any obstructions. Again, use caution against too much pressure, to avoid dislodging tube. Any reliable refrigerator repair service shouldnt charge much more than $100 to resolve this issue.
Mar 28, 2010 | Jenn-Air JCD2389G Side by Side...
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
My freezer has water that leaks into the bottom and freezes but water also leaks out onto the floor
Inside the freezer at the bottom in the back there's a drain hole that must be clogged and the water from every defrost cycle freezes up and make it worse , so first pour hot water into the drain to melt the ice and keep pouring until it goes through .Keep the drain clean doing this every 3 or 4 months.
Aug 10, 2009 | GE Refrigerators
Jun 02, 2009 | Refrigerators
12 yr old ge refrigerator leaks water on kitchen floor occassiona
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
