Question about Grizzly Big Bear Atv Maintenance Free Battery
Is there a decompression valve on a 2005 660 Yamaha Grizzly?
Battery is dead and cant hardly pull start, Is there a decompression valve on motor?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Yamaha Master
  • 1,727 Answers
Most likely not and if there was it would be built into the valves/cam or you wold have a lever you would need to operated the decompression valve just to start it normally with the starter...
Posted on Dec 29, 2013
How can I install a pull start kit?
google search Yamaha Grizzly Pull Start Kit instructions and choose images to get exploded view.
link is the install, should be the same as yours.
press the helpful button
Yamaha Big Bear 350 recoil start install
Jan 31, 2016 | Yamaha 2011 Grizzly 450 Auto 4x4
How to install a pull start on my atv
[PDF]GRIZZLY 450 YFM45FGX OWNER'S MANUAL - Yamaha
www.yamaha-motor.com/.../lit-11626-21-46_griz... Yamaha Motor CompanyThis ATV should not be ridden by anyone under 16 years of age. ... Product and specifications are subject to change without notice. ...... Recoil starter. 4. Throttle ...
Jan 30, 2016 | Yamaha 2011 Grizzly 450 Auto 4x4
My 4wheeler only has a pull starter but has a battery. is the battery necessary to start the machine being its a pull start(07 yamaha 350 grizzly)
Hi Gawan:
Here's an excellent link:
http://www.yamaha-motor.com/assets/service/manuals/2009/lit-11626-22-48_griz_3504wd_1620.pdf
I read a bit of the info and it looks like it does not have to be fully charged, but I would definitely NOT run the engine without a good battery installed. There's way too much potential to mess the electronics.
Jul 13, 2015 | Yamaha Motorcycles
My 2000 yamaha 1600 clicks when I try to start it
The clicking may be the starter solenoid. Check for a dead battery or defective solenoid.
Mar 28, 2014 | Yamaha Road Star Midnight Silverado...
Backfires when you try to rev up engine,
check fuel flow and check spark at spark plugs
According to an "ATV Rider" 2009 article, "When the Grizzly was introduced in 1998 as a 600cc machine, the top was blown right off the displacement wars of the time."
It was replaced in 2002 with Yamaha Grizzly 660, an even bigger engine derived from the well-established all-terrain vehicle (ATV) Yamaha Raptor 660R.
Grizzly's 660 cubic centimeter (cc), four-stroke, liquid-cooled single overhead camshaft, five-valve engine performs well in open country, but sometimes it causes serious problems for owners.
Before you call a Grizzly dealer, however, trying a few tricks in your garage can save you a lot of time and money.
Check the fuel level.
Locate the fuel meter indicator on top of the multifunction display.
If it does not work properly, open the fuel tank, and push the Yamaha 660 Grizzly side to side.
Ensure the fuel is not contaminated by water or rust.
If you have not driven your Grizzly 660 for a long time, drain the tank completely, and fill it with a fuel tank cleaner.
Check fuel hoses for cracks or leakage.
The hoses should be soft and simple to bend.
Replace those that show any sign of wear.
Check the compression.
Screw a compression tester into the spark plug hole, and press the electric starter button.
If no compression exists, contact a Yamaha dealer.
Wipe wet or dirty electrodes with a dry cloth.
The spark plug gap should be checked regularly
Correct the spark plug gap.
Measure the gap with a wire thickness gauge.
If necessary, adjust it to 0.8mm using a screwdriver or replace the spark plug.
Use only a Yamaha-specified spark plug.
Check the Yamaha 660 Grizzly's battery.
Operate its electric starter.
If the Grizzly starts quickly, then its battery is in good condition.
If the engine turns slowly, check the battery lead connections, and you may need to change the battery.
If the engine still does not eventually start, your Grizzly is beyond home repair.
Jul 23, 2013 | Yamaha 2005 Grizzly 660 Auto 4x4
I have a Yamaha Grizzly 350 that won't start/turn over.
Check the starter motor on the bench clamped in a vice ,you may have sluggish or worn brushes .
Mar 16, 2010 | 2002 Yamaha TT-R 250
1998 yamaha grizzly engine noise
you may have a collapsed lifter
Jun 21, 2009 | 2000 Yamaha TT 600 R
2007 Yamaha grizzly 660 wll run fine, and then will die and is hard to start. Carbourator is clean. Does anyone have any suggestions?
CHECK VALVE CLEARANCES(INTAKES MOSTY) IS IT ONLY HARD TO START AFTER IT HAS BEEN RUNNING(HOT) OR IS IT HARD TO START COLD TOO?
Apr 29, 2009 | 2006 Yamaha XT 660 X
Electric start on 640 pulls dead
put bike into 2nd gear while on the bike and push backwards until the bike goes no further.put back into nuetrual.should start easier.works on my 640 when its slow to start
Mar 29, 2009 | 2002 KTM 640 LC4
Grizzly Big Bear Atv Maintenance Free Battery Logo
170 people viewed this question
Top Yamaha Vehicle Parts & Accessories Experts
Andrew Taylor
Andrew Taylor
Coss
Jeff Youtsey
Jeff Youtsey
Are you a Yamaha Vehicle Part and Accessory Expert? Answer questions, earn points and help others
