Question about Samsung SyncMaster 932B LCD Monitor
Samsung SyncMaster 932BW After returning from Tech Service, kind of little dusty black points (like dead pixels) appeared in the display, also one or two tiny like hair micro objects. Is there a way to clean this? since they are behind the front (people at service found it very strange since, as they told me it is all sealed) but I`m sure it happens to them when they opened (to look for a little noise that drives me there) Somebody help me please `cause I`m a graphic designer and I want my display CLEAN and free of bizarre points. Thanks in advance.
  • 4 more comments
  • skyluco May 18, 2009
    Thanks frankzjm for your concern.
    I was there because of an almost imperceptible constant pitch (it`s a F note in a guitar). It becomes audible only when the image appears
    in the display, not when I turn it on (blue light on). I mean, if I just turn it on with black screen and computer off, there`s no noise.
    They say It`s normal which I don`t think so (they didn`t solve it)
    I have read in the web that some people have the same problem and it`s seems to be related with an internal capacitor.
    Any suggest?
    Thank U.
    Hi frank.
    First of all sorry for my english (I live in Chile so I speak spanish),
    so maybe I can`t make myself clear.
    What I`m trying to say is that I have two different problems.
    One is the kind of annoying "little electrical or magnetic noise"
    (but I can live with) and the other, is how can I clean the display that it seems to me dirty from behind. It`s like trying to clean a window glass at home but from the outside.
    Got it?
    Thanks again.
  • skyluco May 19, 2009
    Thanks again dear frankzjm.
    I think same as you.
    Knowing that the panel inside is vacuum is very rare got dirty but definitively these "things" are living inside. (think have to live with)
    Thanks again my friend for your concern.
  • Frank Zhang
    Frank Zhang May 11, 2010
    thanks for your feedback, you means the LCD screen inside surface dirty?
    1) you need to know the panel inside is vacuum, and it is very rare got dirty but except someone open it. if you are very sure the panel dirty inisde the surface of glass ( basicly it is not nly glass), it is very hard to clean the inside surface, also it is much risk to danage the LCD panel.
    2) you can clean the dirty of the surface, using soft cotton and make a little wet, clean from right side to lift and keep one direction. if still not gone, don't try to fix anymore.
    just make a sense.
  • Frank Zhang
    so the same "imperceptible constant pitch " before the sevice done, your describle can not let me to make sure whats problem location with your LCD screen. the constant noise dots more % wrong come from the LCD panel.its self which is hard to fix .
    just make a sense. sorry I can not give you a solution to fix it due to I can not see real symptom.
  • Frank Zhang
    whats the problem your monitor had before service?
SOURCE: samsung monitor problem
update the driver of your video card or download the Everest Ultimate Edition
Posted on Aug 07, 2008
SOURCE: Syncmaster paower button blinking and no display
I have a Syncmaster 204B which had the same problem, I followed these instructions, and sure enough the same two caps were vented. I replaced them with new ones (using 1000 µF instead of 820 µF as it was all I could find and the guy at the electronics store told me that there was a wide tolerance. It is now working like new.
Thank you for the tip!
Posted on Jan 31, 2010
Keynan
  • 977 Answers
SOURCE: Samsung SyncMaster 713BM
Hey!
Follow the instruction below to solve your problem:
Restart your computer and enter Safe Mode (press F8 right as the computer starts booting up. Choose Safe Mode in the menu, press Enter twice).
While in Safe Mode, open Control Panel and go to Add/Remove Programs (Programs and Features on Vista/7) and uninstall the display driver software/drivers.
Restart your computer and boot normally. Now you should be able to see everything. Things might look bigger and uglier, that because there's no display driver installed. All you have to do now is reinstall the display driver. Use it's original disc or go to the manufacturer website and download the latest driver.
Pelu.
Posted on Mar 27, 2010
SOURCE: Can someone tell me how to open the case of my
1.follow this first
2.Turn the monitor so the front section is facing
upwards. after completely pulling this front cover,
Turn the monitor so the back of it is facing
upwards. Lift up and remove the back cover.
Posted on Oct 03, 2010
  • 1684 Answers
SOURCE: dark screen samsung syncmaster 920 N strange noise behind it
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Jan 18, 2012
Dead pixel
It might, somes companies won't honour warranty unless you have 3 to 5 dead pixels. Go to www.samsung.com and contact customer support to see what can be done.
May 09, 2012 | Samsung SyncMaster B2030 20-inch...
When computer is starting up monitor goes blank. I have to turn it off and back on
Sent in for warranty repair to Samsung. Appears there has been some problems with 932B & 932BW.
Nov 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Water in LCD display
Once you get a dead pixel (black dots), there is no way to repair that part of the screen
Sep 20, 2009 | Computers & Internet
Black spots appeared on 17" LCD Monitor-SyncMaster740N
you might have what you call "dead pixels" or a "stuck pixel" try a simple test like this one now it is not the most creative one, but it does help to see if that is the case. u might be able to Fix a STUCK pixel, but unfortunately you can not fix a "DEAD pixel" simply because it is DEAD.
try this website for simple fix instructions.
if is dead pixel what you have, if u can live with it, great, if not , it might be a good reason to get yourself an another monitor.
Good luck
Jun 17, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 913v Monitor
if there are too many black spots already then that means there are lots of dead pixels on your lcd and it cannot be repaired anymore. that will continue to add more dead pixels and eventually damage the device.
Aug 24, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 920NW
Good morning! kindly review the operations manual included when you bought the unit, takeing note on the best set-up settings of the display properties. Otherwise, you may opt to set it to other resolutions that will support the best display. best regards.
Aug 12, 2008 | Samsung SyncMaster 920NW Monitor
Red pixels on the Srceen
Dead or stuck pixels are not uncommon in LCD displays, and the less you pay, the more likely it is to happen (as a general rule) Most manufacturers will a dead pixel warranty, ranging from 7 days to lifetime.
Read your warranty carefully, and speak to the place where you bought your display.
I hope that helps, if you have any further problems, please add them ass comments to this question. If I have been able to answer your question (or not) please click on one of the ratings buttons to let everyone know how I did.
Thanks for your feedback, and good luck.
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Black Spot
Dead Pixel Test This free utility enables you to easily test your digital camera for dead and hot pixels. http://www.starzen.com/imaging/deadpixeltest.htm
Sep 12, 2005 | Fuji FinePix S7000 Digital Camera
Samsung SyncMaster 932B LCD Monitor Logo
491 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
