Question about Nixon Sentry Watch
The day won't change
Day won!t change when the knob is half open
How can I ajust date (day and month)? AR0709
Usually to change the date and time with a watch you pull the knob out on the side half-way instead of the entire way. When it's pulled out half-way, that should let you turn it to change the date and time.
Mar 10, 2011 | Giorgio Armani Emporio Armani Classic...
I have a tonino lamborghini watch and cant figure out how to set the time
The stainless steel band broke on my Tonino Lamborghini watch. Can anyone tell me how and where to get a new band? Or even a replacement link for mine?
Jan 07, 2011 | Bulova Watch
I cannot set the day on my new Timex indiglo watch. i can change the time and date, but the day will not budge. bobdar@att.net
Pull the knob all the way out, then spin the time either forward or back enough hours to reach the correct day. Then push the knob half way in, and reset to the correct date.
Dec 27, 2010 | Timex 27191 Wristwatch
CY2068 HOW DO YOU CHANGE DATE AND DAY
Pull the crown half way out to set the date. To set the day, keep advancing the time - 24 hours for each day. The day will change at midnight each 24 hours. It's a time consuming but one-time-only effort as long as the battery is good.
Sep 25, 2009 | Callaway Golf Sport Series Chronograph...
Change the day of the week
Most watches have a stem that you pull out to set the time. The little knob on the end of the stem is called a crown. For a day/date watch, there are two clicks. The first click when you pull out the stem is the day / date setting, the second click sets the time.
When you are on the first click, twisting the crown one direction changes the day of the week; twisting the other direction changes the date. If yours has only the date, it could be either direction depending on the manufacturer.
Jun 15, 2009 | Guess Collection Textured Dial Watch
Calendar "Day" is stuck beteen days
pull the dial out half way, and turn it forward to adjust the day, and dial it backward to adjust the date.
Mar 16, 2009 | La Crosse EH-21GA Wrist Watch
Day Date
Plain and simple, It is in need of a service. My recommendation is to take it to an independent watch marker. My watchmaker is $125 for a full service and has a 2 day turn around time. VS Rolex is $550 plus and who knows how long.
mike - www.consumerwatchguide.com
Jul 27, 2008 | Rolex Day-Date President 118238 Wristwatch
Fossil JR9589
(I'm dutch, so I'll try in my best englisch)
I don't know if you still have the problem, but what you should do is te following:
* pull out the knob (2 times) and turn anti-clockwise to change the time
* keep doing until it's 24.00 (midnight) and you day change's to the UK (!) day.
* push back the knob (1 time) and change the day to the FRANCE (!) day by turning anti-clockwise
* pull out the knob again and turn anti-clockwise to change the time until 03:00 (midnight)
* you see the then change the day back to the UK day
So, every night at 00:00 the day changes to the FRANCE notation and at 03:00 it then changes to the UK notation, so you can enjoy this setting during the day.
Good Luck.
Also owner of JR9589 watch.
May 26, 2008 | Watches
Adjust the date and day on a festina 3 dial watch
I've just worked it out! Change month....depress inset button on side above hand winder. One push with cocktail stick or similar will advance month. Change date.....pull out hand winder half way, turn knob anti-clockwise until desired number is met. Change day...... pull out hand winder fully, turn clockwise passing midnight repeatedly until day is set, continue to set time, keeping an eye on 24 hour display for am/pm.
All the best, Bob
May 06, 2008 | La Crosse Technology E. Howard Ambassador...
Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Oct 24, 2007 | Watches
Nixon Sentry Watch Logo
136 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
