Question about Frigidaire Affinity FAFW3801LW 27" Front-Load Washer with 3.26 cu. ft. Capacity, 5 Wash Cycles, Vibration Control System, TimeWise Technology, Fresh Water Rinse and Express-Select Controls: Classic White
Error code e62 frigidaire washer dryer
When drying error code e62
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: high efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Posted on May 30, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
  • 193 Answers
SOURCE: my frigidaire affinity front load dryer shows the
AD is a indication of board problems.I would unplug the unit for 20 minutes to see if unit will reset
Posted on Nov 10, 2009
  • 410 Answers
SOURCE: My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
I have a Frigidaire Affinity front load washer ATF6000ES. The lights on the control board go on and off on their own and it beeps at the same time. I've tried resetting it but have the same result. When I...
Thank you for your inquiry, Steve Lesko!
I understand that your Frigidaire washer is displaying an error code of "E62" and the lights on your panel go on and off with a beeping sound. I do not show "E62" as a valid code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your range. You can do that by disconnecting the power from it for roughly ten minutes. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or other error codes? With this information I can better address the issue at hand. In the meantime, I suggest resetting your washer. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E62". I look forward to assisting you. -Matt
Jan 30, 2015 | Frigidaire Washing Machines
Code e62 on frigidaire gallery series model GLTF2940FS2
Good Morning Friend,
I understand you are receiving an E62 code on your Frigidaire Gallery washer, model# GLTF2940FS2. The E62 code means that there is a communication problem between the different control boards in your appliance. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire GLTF2940F Front Load Washer
E62
Good Morning John, thank you for your post!
I see that your Frigidaire washer is continuously beeping and displaying error code E62. However, I show that the correct error code is EB2. Typically, EB2 indicates that the incoming line voltage is above 130VAC. Please verify that the power supply is correct. You may also disconnect the power to your washer for up to ten minutes by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, it would be advisable to contact a professional the since the main control board is possibly faulty.
May 23, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer turning on and off with beeps showes e62 error
Hello coollove60, thank you for your post!
I understand your washer shows error E62. However, it appears the correct error code is EB2. Typically, it indicates that the incoming line voltage is above 130VAC. Verify power supply is correct. If so, it would be advisable to contact a professional the since the main control board is possibly faulty.
Jan 25, 2014 | Frigidaire Affinity ATF7000E Front Load...
Error code
E62 = System Contact Error. System contact error is just a fancy way of saying the washer has a loose connection. This connection can be anywhere on the machine, so check all connection plugs by unplugging and re-connecting all connections one at a time. If you don't find a loose connection, replace the control panel.
Read more: http://www.appliancepartspros.com/ge-main-pwr-board-we4m488-ap4980176.html#ixzz2qOlJ8wDy
Jan 13, 2014 | Dryers
LA secadora G,E, DBVH520 MUESTRA ERROR EN TABLERO E62,NO FUNCIONA
E62 Comm error between control and motor. Check all wires for breaks before changing any boards. Have you kept liquids on top of the washer? Some of this could have dripped into the control panel:
Aug 08, 2012 | General Electric GE DBVH520GJWW 27" Gas...
Frigidaire Affinity FAFW3801LW 27" Front-Load Washer with 3.26 cu. ft. Capacity, 5 Wash Cycles, Vibration Control System, TimeWise Technology, Fresh Water Rinse and Express-Select Controls: Classic White Logo
266 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
