Question about Amana Washing Machines
Does not enter drain and spin cycle on delicate setting
When using the delicate cycle only, the machine does not automatically go into the drain then spin cycle. I have to shut off the machine and put the dial where it should be so that it will drain then spin. If I do not do this the machine will continue with the wash/agitation cycle all the way around the dial repeatedly until I shut it off.
    New Friend:
Machine stop at 51 sec after started ,start button flashing nothing is happening ?
Posted on Dec 29, 2013
SOURCE:
blueextc3221
  • 15935 Answers
SOURCE: My Maytag SAV515DEWW clothes washer,
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
SOURCE: Maytag washing machine skips rinse cycle
Don't know how to solve it, but I do know that the Solution #1 is WRONG.
I have a 5 year warranty on my washer, but I hate people coming into my house. Background check or not, people are people.
Any ways, when they do fix my problem I will let you know. It's an electrical problem.
I know our electric meters are running, but all you have to do is put the washer on "SPIN" cycle, and it will spin and the water will come out. Or you can put your washer in RINSE cycle, since it did not actually rinse.
I was standing and I watched my washer fill 3/4 full with water, and the skip to "COMPLETE" all on it's own. It was suppose to fill all the way to FULL.
Thinking though, I have well water, and I have rust in my water, and I noticed that my water is pouring slower into the washer, maybe there is a clog with rust or something I'll have to clean the filter, but any ways, maybe the washers have a timer, and when it's to the time it should be complete, it skips to complete. It does take DOUBLE time for my water to go into the washer. I was standing there for several minutes.
Any ways, I hope that will help. My washer first did that a few months ago, it didn't do it again, I didn't think anything of it, then it did it again last month, and about every 2 or 3 washes, it does it. It's NOT the weight of my clothes! I wash mini loads and it does it.
Posted on Dec 13, 2009
SOURCE: magic chef washing machine
Water is leaking all over the floor from the bottom of the machine when it is filling up. Can you tell me how to fix this problem.
Posted on Nov 08, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
localwonder
  • 6784 Answers
SOURCE: Washer stops before the first spin cycle after it has drained and continues when I spin the dial a bit.
HIm this is a faulty timer control. simply replacing this device will fix this issue.
CLICK HERE
Posted on May 21, 2009
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
My GE Front Load Washer (model WPXH214FWW) remains in the 'drain' cycle between the main wash and rinse cycles. It will only move to the next cycle if we manually advance the knob (slight turn)after which...
Before replacing the timer, check the cold water inlet. Rinses usually use cold water only. The screen inside the valve, right where the hose screws onto the machine, may be blocked. If not blocked, check the inlet valve solonoid coil to see if it is open and in need of replacement.
Oct 15, 2008 | Washing Machines
My washer recently hasn't drained all of the water during the spin cycle.
how is the spin in the delicate cycle compared to the reg cycle?
Apr 11, 2015 | Washing Machines
Wont drain in automatic cycles
maybe is necesary to set the drain operation in the automatic cycle,like you can set the temperature of the wather ,the time to prewashing and so on.
Dec 26, 2013 | Whirlpool Washing Machines
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
Water is in the drum after a complete washing cycle, you can't see the water but you can here it slushing around and leaves a foul order when not used for several days.
Make sure that the outlet hose is not blocked and the filter is clear.
If this is OK then the following from Maytag may be helpful. If not call a repair man for service.
Is the Delicate or Hand Wash cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such as the Delicate or Hand Wash cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to protect the delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was Max Extract selected?
Ideal for heavy loads such as towels and bedding, Max Extract removes more water from loads during spin.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select Drain/Spin or Spin Only cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form or hose retainer on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manuals and Literature search below.
Is your outlet voltage low?
Check the electrical source or call an electrician.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
See also: Why HE High Efficiency detergent is required.
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin,
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Gerry Harvey
Gerry Harvey
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
