Question about Samsung LN-S4041D 40 in. LCD HDTV
Samsung LCD 1080 flat screen tv model LNT4661FX/XXA clicks before taking 30 seconds to turn on.
  • Samsung Master
  • 717 Answers
Delay in turning on in flat panel TVs is mostly caused by weak and defective electrolytic capacitors in the power supply board. Most of the times they are easily recognized by their bulged top. Some times one has to hunt for them. If one can do it, it is a simple job. Good luck to you.
Posted on Dec 29, 2013
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
johnnydiode
  • 647 Answers
SOURCE: My Samsung 40
The power supply capacitors are getting bad - 1000uf 10V- they need to be changed before they blow completely - dead set.
Posted on Oct 03, 2009
SOURCE: Samsung 40" tv won't turn on
i had the same problem, you'll have to call the samsung service center. You TV's part which looks after the voltage connectivity has failed. This majorly happens due to voltage fluctuations. The part will cost around Rs. 2800 and service charges will be applied by the company.
Posted on Jan 04, 2010
  • 12 Answers
SOURCE: Samsung LNT4661FX/XAA 46 in. HDTV LCD Television -
Got to Samsung's support site and fill out a request:
http://www.samsung.com/us/support/service/request
You will be contacted by your regional repair center. I'm located in Milwaukee, WI and was contacted by a repair center in Elgin, IL, which is 60 miles away.
The regional center said they think it probably is a electrolytic capacitor issues, as multiple models of Samsung LCD's have this issue. They have defective (too low voltage) capacitors which will eventually give out. Unfortunately he said my model was not on the list they have for a free fix. He gave me the number to Samsung's Executive Customer Relations department, which I then called immediately. The woman there checked and found that my model indeed was covered - she updated the Support Request, and instructed me to call back the regional repair center.
I called back the regional repair center (immediately after finsihing with the ECR) and got a different person on the phone, and gave them my ticket number from my original request. He said since ECR updated it stating my model was covered they would fix it for free. If it's not the capacitors that are causing the problem I will be charged a 150$ fee, plus any parts required to fix the TV. I agreed to that since my local TV repair quoted me 200$ to fix the capacitor issue alone.
Today is January 25th, they have me scheduled to have a repair tech come to my place January 7th to do the repair.
You can fix the capacitors yourself for very cheap, maybe 20-30 bucks if you don't have anything: soldering gun/solder/flux/capacitors/etc...
I'd just go through the service request path, get it fixed for free and have a professional do it. Total time for me was 2 minutes for the service request, 10 minutes on phone for regional repair center, 10 minutes for ECR, 5 minutes for regional again. The repair is expected to take 15 minutes - most likely they'll just swap out the entire power supply board rather than the individual capacitors. Basically 1 hour of time to save minimally 150-250 dollars. I bet not many people asking to fix this make 150 bucks an hour...pretty simple math I think.
-Ryan
Posted on Jan 25, 2011
SOURCE: Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Posted on Mar 14, 2009
I have a samsung lcd lnt4661fx/xaa tv and the picture is all blurry, how does this get fixed and how much will it cost me
Does it improve when the set warms up? Is it the entire screen or just the left or right side? These sets are notorious for faulty LCD panel tabs which causes blurry/delayed picture problems.
Mar 11, 2013 | Samsung Televison & Video
Samsung LNT4661FX/XAA 46 in. HDTV LCD Television - When tv is turned on it makes a clicking noise for about 15-16 clicks. Progressively worse. Finally comes on
Capacitors are bad on the power supply board, they will probably looked bulged at the top. I've enclosed an example.
Jan 02, 2011 | Samsung Televison & Video
Samsung 42" LCD
GO TO A SAMSUNG SERVICE CENTER THEY WILL REPLACE FOR FREE DEFECTIVE CAPACITERS
Jul 30, 2010 | Samsung 46 in. LCD HDTV
Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 27, 2010 | Samsung LNT4642H 46 in. LCD Television
http://www.youtube.com/watch?v=Mm51C_RDIZE
-and-
http://www.youtube.com/watch?v=BNHHrgX_6cs
Jan 27, 2010 | Samsung Televison & Video
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Yes, you do need to get the LCD repair before the warranty expires. Call the manufacturers to find an authorized service center near you.
Good Luck.
Aug 15, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-S4041D 40 in. LCD HDTV Logo
Jerry Greenberg
Jerry Greenberg
