Can I use the satellite dish as a television antenna?
  • Televison & ... Master
  • 9,587 Answers
No . Unless the tv station is 36 thousand miles out in space and is transmitting on a satellite frequency your old antenna is worthless
Posted on Jan 06, 2014
I am trying to setup a new lg tv but it will not recognize my satellite channels
When you are setting up your remote, make sure it is on Satellite and not on Antennae or Cable mode. Good luck
Jan 03, 2017 | LG Televison & Video
I do not have a satellite sisgnal
check power and tv in correct mode -then check alignment of dish --if good and no large storms in area notify sky of problem it may be box or programming
Aug 16, 2016 | Televison & Video
How to connect television to satellite dish
gosh with the cable from the dish usually same place the antenna leads go . might need a spliter
Mar 26, 2015 | Televison & Video
My LG Television does not recognize local over-the-air stations.
somewhere in the main menu it asks for input . that needs to be set to antenna or air .once you find that and put in the right kind of input then do the autoscan.
Jan 24, 2015 | LG Televison & Video
My tailgater satellite won't connect to the satellite
Make sure you have a clear view to the south west, that your tailgater is level, and that your receiver is plugged in, you may have to run a check switch test (menu, 6-1-1) if this receiver has connected to antennas other than the tailgater.
Apr 22, 2013 | DISH Network tailgater Automatic Portable...
How do i upload the operational directions for my 500 satellite computer on my computer
Sony Satellite Dish Antenna Operating Instructions
Operating a Sony satellite dish is a process that first requires correct dish placement to ensure strong signal reception. Additionally, the satellite receiver must be installed, and only then can you use it to put the dish in operating order via the use of its signal meter screen. Fortunately, you do not need to be a professional to complete these operations properly.
  1. Initial Sony Satellite Mounting
    • Look around for a suitable mounting area for your satellite dish. This mounting area should be free of any debris and also allow for a flat mounting area. It's best to utilize a hand-held level to measure and make sure that your Sony satellite dish lies flush with the mounting surface beneath it. Also, look to the skies above before settling on a mounting area, as obstructions such as trees, power lines and tall buildings can block signal reception for your Sony satellite dish. Once a spot is chosen, go ahead and crudely aim your Sony satellite dish to the southern sector of the sky above. This will save you some time later when you return for further adjustments
Read more: Sony Satellite Dish Antenna Operating Instructions ' eHow.com http://www.ehow.com/way_6312070_sony-dish-antenna-operating-instructions.html#ixzz1NYml5eFe
May 26, 2011 | Toshiba Computers & Internet
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
No satellite
probably fried the lnb on the dish or the receiver itself
May 07, 2008 | TruTech PVS2119 19 in. LCD Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
