Question about 1998 Chevy C/K Pickup 2500 Performance Exhaust System
Hi. i have a 98 chevy 4x4 k 2500. the spider injectors wont hold fuel pressure
I put a tester on it and it reads 65 pounds of fuel. when it kicks out the gauge drops to zero and gas is going back down the return line to tank.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
When it kicks out ??? explain more please
Posted on Dec 29, 2013
  • 22 more comments
  • andy groves
    andy groves Dec 29, 2013
    ok. i have the fuel pressure gauge on the line. i get in and turn the key, the gauge goes up to 65 pounds, fuel pump kicks off and gauge drops back to zero. the gas is going back down the return line to the tank. its suppose to hold pressure in the spider and wont.
  • andy groves
    i put a new fuel pressure regulator and fuel pump in.
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Dec 29, 2013
    defective spider... key on computer cycles fuel pump for two seconds, will not turn it back on until it sees oil pressure... most likely you have a blown defective regulator
  • andy groves
    i have other spider injectors ive tried and there the same way, dont understand how the spiders work.it starts and quits, but its tore apart now, trying to figure it out. oil pressure was above 40 the last time it ran
  • Behind_Blue_Eyes
    how about we start over... whats the problem ???
  • Behind_Blue_Eyes
    how do you know its returning to the tank and not leaking out of an injector???
  • andy groves
    i have it all toar apart. no injectors are leaking. took return off and it pours right out. not sure if my new fuel pressure regulator is bad. spiders are really exspensive. hate to buy one and thats not the problem.
  • Behind_Blue_Eyes
    I know they are. I would check the regulator for proper installation. you say it pours out? does it pour out when the fuel pump is on for those 2 seconds ??? yes, then check and recheck the regulator. if everything looks good then suspect a spider assy cracked internally ???
  • andy groves
    ok. appreciate it. it holds pressure till pump kicks off. im heading out to garage to mess with it some more.
  • Behind_Blue_Eyes
    then it can't be flowing out the regulator... because the regulator is holding pressure... that is a spring loaded pressure regulator if I remember correctly and the only way it can bypass is in the event of over pressurization...
  • andy groves
    andy groves Dec 30, 2013
    nope. its like the gas goes in and turns around and runs back out the return line.
  • Behind_Blue_Eyes
    Behind_Blue_Eyes Dec 30, 2013
    OK so here is what I am understanding... You turn the key on, the fuel pump cycles for two seconds and the gas pours out as fast as the pump feeds it ??? Then you have a malfunctioning pressure regulator, a damaged spider assy and/or both. Now what's puzzling is how you managed to get pressure because you shouldn't unless the regulator is blowing open after it reaches your mentioned 65 psi and then it wont close until all pressure is gone which should led to a defective regulator. So with all this being said. It comes down to back to where you started. Which is what I asked earlier. What was the original problem ???
  • andy groves
    truck starts and quits, will only hold pressure when fuel pump is running, when pump shuts off pressure drops to zero, and gas goes down to tank threw the return line
  • andy groves
    i put two more regulators on that are used that a guy let me borrow. still did the same thing.
  • Behind_Blue_Eyes
    truck starts and quits... which makes sense, pressure then none... it doesnt run long enough to build oil pressure to keep pump running because there is not fuel pressure... ok do you see where I am going here... plug the return line and see if the truck stays running. if it does then the spider is the problem... pressure regulator is vacuum control through the intake plenum if I remember... without vacuum it should hold pressure until the oil pressure kicks up and causes pump to turn on and then with vacuum applied to regulator it keeps the static pressure somewhere between 35-45 psi... so with the engine not running the regulator should hold pressure for hours, roughly... does this all make sense now
  • Behind_Blue_Eyes
    doesnt matter if there is a problem internally with the spider... you can hang new/used regulators all day long. if it cant seat properly the regulator is going to leak past. if something is in the holding it open, its not going to seat properly.... if you plug the return line and cycle the key and it holds pressure, you know your problem is with the spider assy... I don't recall GM every using an electronic regulator... correct me if I am wrong then we look at a hole other problem...
  • andy groves
    everytime i turn key to make fuel pump run, gauge goes to 65, pump shuts off, gauge drops to zero, i unhooked the return line, had a friend turn the key, and gas came out of the return, when pump shut off gas kept running till drained
  • Behind_Blue_Eyes
    dont run it very long with the return line plugged as you will dead head your pump and potentially blow it out...
  • andy groves
    ok, good thing you said that cause i been thinking about putting in a shut off valve to see if truck would run, keeping some gas from draining back.
  • andy groves
    ok. somehow i didnt see your other comments, makes sence, no they didnt make an electronic one, im a big chevy fan, but this is the worst designed motor they ever built
  • Behind_Blue_Eyes
    no its a horrible design for the fuel injection system... the engine itself is actually pretty good... A simple carb, ignition swap and you'll gain about 60 hp :-)
  • andy groves
    i have been thinking about it, just not sure what all i would have to do to make it run
  • Behind_Blue_Eyes
    A lot of work and expense... but cant be much more expensive then the new spider LOL... any good trucking magazine will have how to articles archived, do a search. I stopped driving cars 2 years ago and now I ride motorcycles only...they break, sell one buy another. I've had 3 in 4 years, minimal maintenance :-) but I also live in Florida
  • andy groves
    have to check into it. friend of mine already has the intake, if i knew what distribitor to use and wiring. probably wouldnt be hard to do. its to cold up here for bikes, but that would be the way to go, if i lived down there
Does a 1996 chevy s10 pickup 4.3 vortec have a saftey cut off that will stop the fuel from getting into the spider injectors
Sorry there is no safety valve or switch. Only Ford products use an inertia switch.
Have you checked for power and ground at the injector connector ?
Jun 22, 2015 | Cars & Trucks
What should i look at first. i have 57 pounds offuel pressure but it wont start.have replaced fuel pump,filter.someone said to check the spider first .any help?
The spider is the injector system. They are not cheap and they are a pain to change. Have to take the intake manifold apart.
Jun 13, 2015 | 2000 GMC Jimmy
1998 chevy 4X4 5.7 2500 good fuel pressure but wont stay running
sounds like the same problem im having. starts and quits. gas is running back to fuel tank instead of holding pressure in the spider injectors. I will let you know how I make out with mine in the next couple of days
Aug 31, 2013 | 1A Auto Parts 1998 Chevy Express 2500 Van...
Kawazaki kz1000
What you need to do is check you fuel pressure. Go to a local auto parts store and buy a fuel injection pressure tester. The pressure fitting is on the top of the motor its a 3/8 ish sized metal line and has a screw on fitting like a tire valve does. This line comes up from the back of the motor to the right of the distributor and goes down into the intake. Make sure to have a rag handy to catch the fuel seepage. After you connect the pressure tester turn the key on and off three times and read the gage you should have atleast 58 pounds of pressure. If you have 56 pounds it won't run because the fuel injectors are a poppit valve style and need atleast 58 pounds of pressure to operate.
Apr 25, 2013 | Cars & Trucks
I have a 1998 chevy express van.i have spark and fuel up to the trader valve.the van is not getting gas to start.i am thinking it is the fuel regulator module or the fuel regulater. what do you think?
Put a fuel pressure cage on the Schrader valve to test for fuel pressure. The fuel pump may not be running up to snuff or the regulator may be faulty. The strainer sock on the pickup tube in the fuel tank may have collapsed which will restrict the fuel flow.
Jan 30, 2018 | Cars & Trucks
1995 chevy s10 blazer not holding fuel preasure when not running
The pressure regulator is in the intake manifold when they go bad it either give low pressure or leak out affecting engine performance by burning rich(black smoke)
Mar 01, 2012 | Cars & Trucks
I need diagram to install spider fuel injector assembl for chevy vortec engine
Just put chevy fuel pressure regulator & spyder assy in your search engine
You willl have hours of reading etc
Removing the intake will be a lot of work
Installing the press reg & spyder won't take long or need
instructions.
Sep 27, 2011 | Cars & Trucks
Sounds like the fuel pump is going or gone out and it trys to start but it wont turn all the way over
By what your stating, that it starts and dies every time, It seems to be fuel related. You need to perform a fuel pressure check. You will need a pressure tester, one that would at least be able to read pressure to a maximum of 150 lbs of pressure. Although you really only need about 50-60 pounds of pressure to maintain proper fuel injector operation. There is a test port located on the fuel rail where you would conect the pressure tester. The test port is usually located on the drivers side of the engine near the rear section coming up from the firewall. Unscrew the pressure port cap if its still there and connect your tester. But also keep in mind you may have fuel pressure of some sort in the rail so be careful. While the tester is screwed to the test port you want to cycle the ignition key on and read pressure, you may want to repeat this several times. You must have at least 50 pounds of pressure, if so it should start. If you are losing pressure while your maintaining a visual check on the tester it could also be a faulty pressure regulator/fuel pump or even a rubber hose connection inside the fuel tank that connects the fuel pump to the fuel line. If you have any questions Im here to help. Thanks for using FIXYA
Feb 22, 2011 | 1996 Chevrolet Cavalier
2002 chevy silverado starts right up but then dies right away starts right up again but dies
Feb 22, 2011 | 2002 Chevrolet Silverado
Engine wont crank without prime has good fuel pressure and a new injector spider
This vehicle needs 65 to 70 psi fuel pressure.to start cold, it will run with 55 after priming
Oct 15, 2010 | 1996 Chevrolet Blazer
1998 Chevy C/K Pickup 2500 Performance Exhaust System Logo
229 people viewed this question
Top Gibson Vehicle Parts & Accessories Experts
Marvin Steele
charlie rodriguez
charlie rodriguez
Andrew Taylor
Andrew Taylor
Are you a Gibson Vehicle Part and Accessory Expert? Answer questions, earn points and help others
