Question about Sylvania SCR4966 Clock Radio
Setting the time on sylvania scr4986 - Sylvania SCR4966 Clock Radio
After the time is set ,why does the two dots keep flashing? Sylvania model scr4986..
Manual is here. Not particularly helpful, and only mentions things flashing when setting the clock and alarm. Page 10.
http://ecx.images-amazon.com/images/I/D1bTXCIWrWS.pdf
Mar 17, 2017 | Hardware & Accessories
How do I get my sylvania 10 in. Photo frame video intensity increased
Image Settings; Calendar Settings - Sylvania SDPF751B ...
www.manualslib.com > ... > SDPF751B > User manual
Sylvania digital photo frame user manual. Hide thumbs. 1 · 2 · 3 · 4 · 5 · 6 · 7 · 8 · 9 ·10 ... You can decrease/increase the value by pressing. Time: Press to set Date, time. ... Digital Photo Frame Sylvania SDPF733 User Manual. Sylvania digital ...
Electronics - Sylvania
Dec 10, 2015 | Sylvania Cameras
How to set alarm on Sylvania Scr1986bt
hold the time button down and then tap set see what it does .
Mar 02, 2015 | Sylvania Audio Players & Recorders
Setting clock on Sylvania SCR4986
This is what i found:
Clock Setting
The clock can be only set while the unit is in standby mode
1. While the unit is in standby mode, press the TIME_SET button into clock setting. The LED
display will start flashing, press REV/DOWN or FF/UP to select 12h display or 24h display.
Confirm your setting by press TIME_SET again
2. While the unit is in standby mode, press and hold the TIME_SET button for 2-3 seconds, the
hours will start flashing, press REV/DOWN or FF/UP to set the current hour, press the
TIME_SET button to confirm the setting, then the minutes will start flashing, press
REV/DOWN or FF/UP to set the current minutes, press the TIME_SET again to confirm all
setting. The time is now set
Drew.
Jan 14, 2015 | Sylvania Audio Players & Recorders
How to set time on scr4986
You have to hold the "time button" while pressing the min & hour buttons to set it, and if your trying to set the alarm you hold the alarm button
Aug 12, 2014 | Audio Players & Recorders
Cant set my sylvania outdoor timer, says hit zip set and enter zipcode.i can only get 3 numbers in
Open following link for Sylvania timers.
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
3 numbers is correct.
77482 and 77468 will be inside same time zone.
So set 3 digits 774 and timer knows where you are astronomically.
The timer does not need your full mailing address zip.
Press red reset button.
Press mode button until ZIP icon displays.
Depress and HOLD clear zip-set button until display flashes.
Set first 3 area code numbers.
If zip set is not working correctly, then timer is defective.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 01, 2011 | Zip Heaters Sylvania SA220 15 Amp Zip Set...
Sylvania SCR4966 Clock Radio Logo
35 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
Tre Elkins
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
