Question about Maytag MSD2756GES Side by Side Refrigerator
Warm refrigerator I am having issues with my Maytag MSD2756GES. The freezer compartment only gets to about 40 degrees F and the refrigerator section is about 80 degrees F. I had a young service technician come over to replace a recalled relay for the compressor (the problem occurred prior to all of this). I was hoping that would fix the problem, but it did not. He thought it may be my compressor; however, he didn't really do any troubleshooting to come to that expensive conclusion. before i go spending so much money on buying a new compressor, I would rather troubleshoot this myself and see if I can't find the problem without spending $87/hour for some young kid to get his feet wet. Through other posts, it sounds as if it may be the defrost assembley. Does this sound right to you? Where is this piece physically located?
  • ddal May 21, 2009
    Thanks for the response. Both fans do run when the compressor is running. I decided to check the evap coils in the freezer section and found them completely covered in ice. I defrosted the ice with a hair dryer and then figured the problem must have been the ADC. I replaced it with a brand new one and it seemed to be working. That was about 5 hours ago and the freezer section is only 20 degrees and the refrigeration compartment only gets to about 60 degrees. I also check across the defrost heating element and it was only 22 ohms. That could be another issue and perhaps the initial cause of my problems, but there is no ice build-up right now and it still won't cool. I am very skeptical about the compressor being bad. Do you think it could be the overload or PTC relay? Thanks again.
  • ddal May 21, 2009
    The temps have come down when I checked this morning. So, it is looking good for now.
    As for the defrost element, I thought the resistance should be 240k ohms. Maybe that is through the defrost thermostat? Thanks for the help.
I had the same problem with my msd2756ae. We had been using the blow dryer, removing the rear panel in the freezer section, etc.
We replaced the adaptive defrost control board. Solved our problem. It's an easy replacement, located in the refrigerator section, top right---behind the temp. control slide. The hardest part is removing the top panel that holds the temperature slide. Then it's "pull and replace".
Posted on Jun 26, 2009
  • Maytag Master
  • 4,654 Answers
Some simple things you could check. Can you tell how long compressor runs. Are both fans running while compressor is running? Is the compressor to too hot to touch? Is the condenser under refrigerator giving off warm air? And if all these things together while running and compressor not stopping, what is the freezer temperature and evaporator heat being taken away with the condenser fan? Is your freezer defrosting properly and have you checked the adaptive defrost control. Below is a link to that model. Put model number MSD2756GES into the search model feature and it will take you to your model. Click on photo 2 controls and part # 13 in the controls photo is what you need to have a look at, Let me know what you find and I will answer the compressor change now. ( Not worth changing if refrigerator is old) Let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 18, 2009
  • 1 more comment
  • John Tripp
    John Tripp May 21, 2009
    Right now your refrigerator is trying to stabilize temperature. Just make sure the bottom grate where the condenser coil is located is clear of dirt and dust. The Adaptive defrost will put your refrigerator into defrost after it senses the time it has run with the evaporator cold. Not every eight to ten hours like a defrost timer. Yes there could be another problem, but right now we need to see if the temps will come on down. When they do come down is when we will see if it's defrosting like it should. Give the refrigerator a little more time to get to normal and make sure the coil below the refrigerator is clean. Let me know how it is tomorrow early, The heating element should show no resistance just the same as putting the two leads from your meter together.
    Thanks, Sea Breeze
  • John Tripp
    When you test the defrost element again make sure one wire is disconnected on one end and that the test does not include the defrost thermostat while testing the defrost element..
  • John Tripp
    You are possibly correct as to the ohms on the defrost element. I really never followed the amount of resistance or the measurement. I just always checked an element to see if the element had a broken circuit or not. Maybe I'm to old fashioned, but thanks for the vote of confidence. If there is a problem we know that it may be the only 2 parts we didn't change. I have checked elements before and had a good reading only to find out later that the wire connector had a bad connection. I found that one because the plastic cover on the crimp on wire connecter began to melt. About the only good way to test the defrost thermostat is while it's freezing. They open the contacts at around 50 degrees F. to protect the defrost from over heating and turn it off to keep from causing damage inside freezer. If you ever need to change the defrost element change the thermostat also. Thank You, Sea Breeze
I had a problem with my Refrigerator Model # MSD2756GES. Freezer was fine but the Refrigerator would only cool down to 50. Replaced the adaptive defrost control board and the problem was fixed. Thanks Hydra133 for the help.
Posted on Jul 10, 2009
What is "normal" temperature range for N640 model
Hello Geoff;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer section is +2 to -2 degrees F., and for a fresh food section it is 35-40 degrees F.
These setting may have to be adjusted depending how full the compartments are.
Dec 23, 2014 | Refrigerators
My Maytag MSD2756GES side by side stoped working. The freezer just stays cool around 40 - 50 degrees and won't get any cooler. I turned the temp as low as it gets and no change. I also hear a click...
That is probably the overload on your compressor clicking. Remove the rear panel and listen for it. If thats it unplug ref. and remove compressor cover and remove the starting components. Shake the relay. If it sounds like its in pieces its bad. If not you may have a bad compressor, but I would replace those components first. Check your warranty for compressor.
Sep 27, 2011 | Maytag MSD2756GES Side by Side...
Fridge temp controll is up to 9 the coldest and can only acheive 40 degrees freezer setting is at 7 and will acheive 10 degrees. please help
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 24, 2010 | Maytag MSD2756GES Side by Side...
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
Refrigerator not cooling but the freezer ok
Sounds like the thermostat or control mechanism is broken in the fridge compartment. You willneed to call a service engineer to fix it or risk getting ill.
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
Refrigerator is not working, freezer is working
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 08, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag top freeze freezes food in the refrigerator section
this used to happen to me, it is accualy the ice macine make sure you empty the ice compartment regularly
Sep 05, 2009 | Maytag Refrigerators
Maytag MSD2756GES Side by Side Refrigerator Logo
821 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
