Question about Spyder 88-98 Chevy C/K 1500/2500/3500 Full-Sz/Silverado/Tahoe/Suburban
Spider injectors wont hold pressure, gas runs back down the return line
Has 65 pounds of pressure, when it kicks off it drops to zero
My fuel pressure goes to 60 pounds when the keys is turned on then starts dropping Is it my fuel pump or pressure regulator? 2004 GMC Yukon XL
Fuel pressure may drop due to a leaking injector or bad check valve in the fuel pump itself. The regulator does not come into effect until the engine is running and a vacuum supply is produced to it. If the regulator is leaking internally, it could send fuel back to the tank as well. Prime the fuel line and pinch off the return line ( if possible ) to eliminate a regulator problem. If the fuel pressure drops with the return line pinched off, suspect a leaking injector or fuel pump. If injector is leaking, the vehicle should run rich and cause a hard start/rough run condition
Jul 25, 2015 | 2004 GMC Yukon XL
1998 chevy 4X4 5.7 2500 good fuel pressure but wont stay running
sounds like the same problem im having. starts and quits. gas is running back to fuel tank instead of holding pressure in the spider injectors. I will let you know how I make out with mine in the next couple of days
Aug 31, 2013 | 1A Auto Parts 1998 Chevy Express 2500 Van...
My 1998 dodge neon wont start until i pour gas in the throttle body then dies out when i press the gas
What is the fuel pressure when the engine is running ?
Has the filter been replaced ?
Aug 16, 2012 | 1998 Dodge Neon
99 Tahoe engine cranks, wont start
You need 3 things.
Compression
Good hot blue spark to all plugs.
Good gasoline and proper fuel pressure. 63-64 lbs.
If you have all 3 then move on to injector pulse to all injectors.
I think each injector is on a separate driver on that one.
Check for pulse to all of them.
You may be weak on fuel pressure . even a couple of lbs low on a cold start will cause a no start.
Double check cold start cranking fuel pressure. If under 63-62 lbs you have problems.
one test is to give it a squirt of carb cleaner not starting fluid. If it starts then you have a fuel pressure problem.
Run the full fuel pressure test and post back pressures.
Here is the guide lines on testing.
Hard to start cold.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
The 75-85 is only a check on the capable full pressure of fuel pump.
If you can not find the rubber return line check full pressure by plugging return line or just or the true full pressure can be taken direct at the end fuel filter.
What are the pressure readings that you have done.
What are your cold start pressure readings?
Post back what you have.
The other thing to that is common is the (ICM) under the distributor cap. There is a breather screen on the bottom of the distributor that get's clogged with dirt causing condensation promoting corrosion, this was gm TSB for replacing the cap and rotor to make sure it's clean.
Good luck and hope this helps. Merry Xmas.
Dec 24, 2009 | 1998 GMC Safari
Car wont start. Has spark, tried Carb Cleaner.
Hard to start cold.
Post back what you have. Good Luck
Dec 24, 2009 | 2002 Chevrolet Blazer
Won't hold fuel pressure
Check the fuel pressure at the shredder valve, there should be 60,PSI to 65,PSI for the poppet injectors to work. If the pressure is correct then there is a good chance that the Spider injection system may have gone bad. Recap. Check the fuel pressure at the shredder valve to make sure the Fuel pump is not going bad. There is a valve at the fuel pump that holds the residual pressure in the system, try cycling the ignition three times. Turn the ignition to the run position for 5 seconds and turn it off and do it again for 3 cycles to pressurize the fuel line and see if it starts. If it does not start then check the fuel pressure at the shredder valve. Make sure you have the proper pressure to activate the injector system. If not then get the injector system check for bad wire harness and see if you can smell gas leaking. Oh and the easiest thing to do is change the fuel filter too. Good luck and keep me posted and if you get a chance get the ECM scanned at Auto Zone for free and look for any DTC codes if any have it cleared. Good luck and keep me posted
Jun 04, 2009 | 1999 Chevrolet Silverado 1500
1997 GMC 1 ton 4x4 hard to start after it has warmed up. changed fuel filter no help No code to be read We have notice that the fuel in the rail is vapor not a liquid. Is this normal and if not what would...
The fuel pressure should hold at or near the 45 lbs after you shut the truck off.
You have one of three problems causing this.
One, the fuel pressure regulator is leaking internally and allowing fuel to return to the tank via the return line. To verify, use a pair of pliers and gently pinch the return line off. Turn the key on to the run position, the pump will run for 2 to 5 seconds and pressurize the line. Watch the pressure gauge, it should hold pressure. If it does, change the regulator.
Two, the check valve at the pump is weak. To verify, turn the key to the run position, when peak pressure is reached, gently pinch the pressure line and watch the pressure gauge. If the pressure remains near the peak pressure the check valve is bad. Replace the fuel pump.
Three, if neither of the above procedures work, you have a leaking injector. You will want to remove the fuel rail, pressurize it to find the bad injector.
Any one of these failures will cause the "vapor" issue you describe.
Good luck, let me know what you find.
Regards,
Apr 28, 2009 | 1997 GMC Sierra
Spyder 88-98 Chevy C/K 1500/2500/3500 Full-Sz/Silverado/Tahoe/Suburban Logo
Top Spyder Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Spyder Wine and Spirit Expert? Answer questions, earn points and help others
