Power pass cabinet ups 4500p6hv - Computers & Internet
Recent rain storm, water came out from failed baffle, the power did not trip the circuit, but the unit no longer power's up?
Depending how the unit is installed..you may have a ground fault type outlet up in the cabinet someplace. Maybe on top of the cabinets. This will cut power to the unit without tripping the breaker. Just find the outlet & reset the GFI outlet. Fix the leak.
Mar 01, 2016 | Kobe Brillia CHX191 Series 30-inch Under...
I have no power to the display board on my washing machine, is there a fuse somewhere, a reset procedure, or am I looking at replacing the PCB's
Under the machine inside the cabinet, should be
a diagnostic manual, taped up there, hiding in a bag
You may very well have to replace the control board,
if all tests pass
You have to be able to use a volt meter on live circuit
boards & back probe the connectors, as you do to
test a car
Aug 15, 2014 | LG Washing Machines
Wiring a switch to operate a plug
Use the identified screw (different color then the other two) and any one of the other two. I do not know what switch you have but I assume the two identecial screws are on the same side. Put the one with the wire down, then hopefully when the switch if moved up it will turn or, if backwards just rotate the switch.
Mar 05, 2014 | Pass & Seymour Electrical Supplies
Vanity cabinet with lights needs power
Dimmer wires in series on either wire of the cord.
Nov 27, 2013 | Pass & Seymour Pass Seymour 90611WV 600W...
I just removed the back cabinet of a Whirlpool Duet Dryer and found a dead mouse where the power cord connects to the cabinet. Machine powers up but doesn't turn. I noticed that the neutral spli
if the wire has a metal end on it and its connected to the white wire, or neutral line, then something is wrong and that should connect to something
Jun 05, 2012 | Whirlpool Dryers
I have a Whirlpool Gold Ultimate Care II washer (MOD# GSQ9669LW0) The washer stopped, was full of water and will not restart on any cycle or settings.
This problem sounds like a broken lid switch. Power to the drive motor is routed to the lid switch and if the lid switch fails, the machine will fail work on any cycle. Verify this by bypassing the lid switch.
Disconnect power to the washer then remove the screws securing the console to the rear of the cabinet.
Pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
Jump a wire between the outer terminals of the disconnected connector from the top of the cabinet then reconnect power. The problem is indeed the lid switch if the machine starts. Check the lid switch plunger and the lid switch attachment to the cabinet. It may not activate properly if the mounting is loose, re-tighten it. Replace the lid switch if the plunger is intact and and if it is mounted tightly and properly.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Jan 11, 2011 | Whirlpool Washing Machines
The washer filled up with water but wont turn on
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch. The machine, therefore, will not turn on when the lid switch is not working. Manually activate the lid switch and if still doesn't work, bypass the lid switch. Disconnect power then jump a wire between the outer terminals of the disconnected connector from the cabinet top then reconnect power. Replace the lid switch to address the problem if the machine works with the lid switch bypassed.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Nov 09, 2010 | Whirlpool LSN1000LW Top Load Washer
I Have a IBM THINKpad and forgot the bios pass
Dear user,
pl remove power cable from cpu and open cabinet remove cmos cell and give power and check it. your password is removed.
2nd way is pl set cmos clear jumper in clear mode after given power to cpu.
Regards,
Ravindra Shah
Aug 02, 2009 | IBM ThinkPad T30 Motherboard 91P7695 -...
Ricoh 551
CAREFULLY check that ALL doors and cabinet parts on the machine are PROPERLY closed. Any interlock not being actuated can keep machine from turning on.
Oct 30, 2008 | Ricoh Office Equipment & Supplies
Peninsula otr microwave installation
I cannot comment on this. On something that is non-standard and specifically warned against in the manual, I would only comment if I were there to inspect it.
I would get a pro's on-site opionion.
Jul 30, 2008 | Microwave Ovens
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
