Question about Nintendo Wii Console
Wii reomote handsets
Re-setting hand remotes to your wii console
One of my wii controllers keeps going off in the middle of the games. What do I need to do?
Posted on May 21, 2009
    Sergeant:
  • 273 Answers
Go in to HOME and then remote settings then press buttons1 and 2 togeather after a couple of seconds the wiimote will make a noise and your ready to go hope this helps
Posted on May 20, 2009
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Wii remote cursor hand not appearing on the screen
I am not sure but I had the same problem when I got a second remote hand set and my kids knew the answer. I first thing I would do is to ensure that you have new batteries in the handsets. Secondly there should be a small button inside the handset. I think that you need to push it to synchronize the handset to the Wii base station. I hope that helps
Nov 26, 2010 | Nintendo Wii Console
Lost communications to WII remotes and board
hi, my wii console works exept the little hand from the wii will not go on the screen, the remotes are programmed in and work fine so wondering what the problem could be? if its the sensor bar or something else and can it easily be fixed? thanks
Apr 20, 2010 | Nintendo Wii Console
I am having a problem with the Wii sensor bar. It is
if you can't get any sensor bar to work then it has to be the main board on the Wii is bad since that is where it connects to. If your Wii is under warranty, contact the store to bring it back and get a new one.
Jan 04, 2010 | Nintendo Wii Console
Wii Remote on Guitar Hero 3
try resyncing the other remote.
Nov 24, 2008 | Nintendo Wii Console
New additional handset
try going in to wii settings. An where there batteries are theirs a red button to press to activate it i think. I tried both of these and one of them worked dont know which one, hope that helps
Oct 24, 2008 | Nintendo Wii Console
Console the problem?
game stuck in wii system
Feb 09, 2008 | Nintendo Wii Console
Different handset to original wii console
What about holding the sync button on the Wii remote first, and then while still holding it, press and hold the Nintendo Wii sync button.
Dec 19, 2007 | Nintendo Wii Console
Hand sets do not seem to work
Press and hold the sync button on the Nintendo Wii remote. While holding the sync button, go over to the Nintendo Wii, and and press and hold the sync button. Wait for a few seconds, and then test the Nintendo Wii remote.
Dec 18, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
266 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
