Cursor freezes or is erratic
The cursor freezes or jumps erratically when using Windows Media Centre for TV and Web Browsing on same screen. Switch off/on does not work; New mouse s/ware does not work; change speed of mouse does not work; any more suggestions Please
    New Friend:
    Problem Solver:
  • 11 Answers
Ow, I have had this problem myself. Do you have an iPhone or other Apple device that you've connected lately?
I am assuming your mouse is either Bluetooth or uses a proprietary 'dobgle'...Which?
Posted on Dec 29, 2013
Testimonial: "Nice try...No Apple stuff. Not touchpad. All H/ware o.k. This is out of ordinary software issue"
4 Suggested Answers
PABLOCSA
  • 1124 Answers
SOURCE: Has anyone found a fix
  1. Mouse is not clean.
  2. Optical portion of mouse is blocked.
  3. Moisture or other material on finger.
Mouse is not clean Users who have an optical mechanical mouse (most common mouse for desktop computers) are likely experiencing erratic behavior because the mouse is not clean or is dirty. Optical portion of mouse is blocked
Users who have an optical mouse are likely experiencing erratic behavior because a portion of the optical eye is blocked. Most commonly this is caused by a hair.
Moisture or other material on finger Users who are using a touchpad may experience erratic behavior because of moisture or other material on the finger such as lotion.
Mouse has been cleaned and still has problems If you've cleaned the mouse and continue to encounter issues and this mouse has worked in the past fine unfortunately your mouse is likely defective. One additional test that can be done to help determine if this is the case or not is to connect the mouse to another computer. Otherwise we suggest replacing the mouse.
Posted on Oct 24, 2008
honest1abe
  • 72 Answers
SOURCE: Mouse cursor jumping uncontrollably all over screen.
Your touch pad drivers need to be installed. Power off the laptop. Install an external mouse, power back on and install drivers. When finished, power down, remove the external mouse and reboot.
Posted on Dec 30, 2008
intower18
  • 957 Answers
SOURCE: mouse cursor jumping problem, how
A mouse is a vital component of your computer and allows you to control certain functions on the screen. When the mouse is not functioning correctly, it can be frustrating. There are a few different reasons why your mouse pointer may jump on the screen. You need to work through the possible causes and troubleshoot the problems to fix your mouse and get it working properly again.
1.
Examine the batteries if you have a wireless mouse and the cursor begins to jump. A low battery may be the cause. Change the batteries and check the mouse again. If it is still experiencing the same problems, proceed to the next steps to resolve the issue.
2.
Switch the wireless transmitter to a different USB port on another computer if possible. There could be problems with the port, causing the cursor to jump. This will resolve the problem if the issue is with the USB port. If the mouse is still jumping, move on to the next steps.
3.
Click on the "Start" menu in the bottom left corner of the screen. Right-click on the "My Computer" menu and click on "Properties." Click on the "Hardware" menu and click on "Device Manager." Locate the mouse entry in the list. Right-click on it and select "Update Driver" from the menu. Allow a few moments for the operating system to locate and install an updated driver for your mouse.
4. Remove dust or debris from the mouse pad and mouse with a soft cloth. Dust or debris could prevent the mouse from operating smoothly and cause the cursor to jump. Add a small amount of isopropyl alcohol to the cloth before you begin. Wait for the alcohol to dry on the pad and mouse prior to using.
5. Go to the "Start" menu and click on "Control Panel." Double-click on the "Mouse" icon and click on "Mouse Pointer." Decrease the speed of the mouse pointer. This could be causing the cursor to jump.
I hope you find it very helpful.
Thank you.
Posted on Aug 11, 2011
Cursor jumps to corner of screen, is erratic
have you tried a usb mouse ?? as if that works it will be the touch pad is playing up. you can disable it and use a wireless mouse or usb one. as it would be cheaper then replacing the touch pad.
Dec 29, 2013 | HP EliteBook 2730p Tablet PC
Erratic cursor ms media centre wireless keyboard
What platform? Memory (needed for this sort of task)? WiFi gateway? Model?
Importantly, have you attached any Apple devices to your system recently?
If the connection is Bluetooth (to TV), well, there's not much help for it. You need a lot of CPU and Memory for smooth flow and device functionality.
Dec 28, 2013 | Computers & Internet
On my CF-51 the touchpad is erratic and occasionally the screen cursor will jump. The OS is Windows XP. Everything else works perfectly.
I had similar issues with cursor jumping even while using a mouse.
Very simple & quick fix is to simply "disable" touch pad through "start up" mode use a mouse.
You have to disable in start up menu or pad will re-enable itself next time you boot.
I never liked a mouse before being forced to use it .... now it's not so bad.
Jun 22, 2011 | Panasonic Toughbook CF-51 Notebook
The cursor for my USB mouse will jump around the
2 Possible problems
1 mouse is bunk and fried
2 the mouse connection is fried (motherboard)
You may need you upgrade your usb too 2.0v
Oct 15, 2009 | Computers & Internet
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Erratic behavior of MS wireless optical mouse
Your wireless mouse the battery might be low, change the battery and go to control panel and click the mouse icon, and adjust the right mouse speed setting.
hh
Jul 27, 2009 | Computers & Internet
Erratic movement of cursor
try to re-install the driver of your touchpad. i suspected it could be the driver issue.
May 11, 2009 | Computers & Internet
POINTER FREEZES THEM MOVES THEN FREEZES DRIVING ME NUTS. THANKS
When this behavior is observed when using a Logitech product withinWindows® XP, it may be caused by a feature within Windows called"enhanced pointer precision". This feature may conflict with Logitech's software, causing the erratic movement. Enhanced pointerprecision became available in Service Pack 2 and therefore is notapplicable in any version of Windows® XP without Service Pack 2installed. For more information on enhanced pointer precision,please click HERE. If this link does not work, then you should go to Microsoft and search for Knowledge Base article 895550.
Please see these articles from the Logitech database for possible troubleshooting tips as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
Troubleshooting: Erratic Cursor Movement in Optical Mice and Trackballs
Mouse cursor is uncontrollable or behaves erratically
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Interference with Cordless Products
Download latest version of software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 27, 2008 | Logitech Cordless Mouse
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
