Question about Danby DTT420W Portable Washer
Spinner will not spin - Danby DTT420W Portable Washer
What is fidget spinner made up of?
Fidget spinners are the type of fidget toys which are made up of various different types of materials.
Basically, they are made up of metals like made of steel, copper, plastic, brass or titanium. Some spinners are also available in 3D printed designs.
These Fidget Spinners toys have become very trendy today due to its various health benefits.
Jun 02, 2017 | MADE Computers & Internet
Spinner only spins one way .
I have the same problem the spinner spins one way, after attempt to change the motor drive it can't spin any more what's the problem
Mar 16, 2014 | Danby DTT420W Portable Washer
Where can I buy a salad spinner? It'd be a bonus if it had a brake in it to stop the spinning.
With a brake!! enjoy :)
http://www.target.com/p/oxo-salad-spinner/-/A-628331
Jan 14, 2013 | Home
Top rack spinner is not spinning
First check - ensure that the jets at the end of the spinner blade are not blocked. Check that the spinner is not siezed by turning it by hand, other than a cracked or disconnected pipe, there can not really be another reason for the spinner not rotating (if the bottom one rotates).
Jan 15, 2011 | KitchenAid Dishwashers
have kenmore 70 series washer model: 110.7015626w that will agitate but sluggishly and will not spin but the belt is getting hot (drum is not spinning but the motor is running).
Dec 17, 2009 | Kenmore 22422 Top Load Washer
I put the game in but the disk does not spin
try cleaning the spinner and laser and make sure the spinner and game make contact to where they spin. it might be that your tray is kind of crooked and it misses the spinner to where the game wont spin.
Dec 08, 2009 | Sony PlayStation 2 Slimline Console
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
The spinner bush turns really slowly. It doesn't
u need to get a new belt. a local hardware store or walmart carries it. also u need to take the vacum apart further so u can clean out where the motor spins u will get much bettter results
Oct 06, 2009 | Eureka Vacuums
Top rack not cleaning, possibly spinner not spinning?
Try twirling the spinner by hand to see if it is binding. If it looks ok then there could be something plugging the water passage to the spinner. If you have access to a water hose you could run water into that verticle passage pipe and see if there is an obstruction. If so it can be taken apart for cleaning.
May 13, 2009 | GE GSS1800H Built-in Dishwasher
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Danby DTT420W Portable Washer Logo
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Samyfam
Samyfam
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
