Question about Cell Phones
My phone has colored lines and it's not working
  • 32 Answers
How could your cell have colored lines when it's completely wireless ?
Posted on Mar 24, 2014
Phone Jack Wiring Problem
Your apartment is wired for two lines but you are using only one of the two. Your phone jack has red and green terminals for one line and yellow and black terminals for the other (old color codes). The four wires coming in to your apartment are actually two lines: orange/white and white/orange plus blue/white and white/blue (new color codes). One of those lines is active. Connect the orange/white wire to the red terminal and the white/orange wire to the green terminal. Plug in your phone and listen for a dial tone. If no tone, disconnect the first line and connect the second pair of wires. Listen again. DO NOT CONNECT ANY WIRES TOGETHER. Just follow the steps above. If you still don't get results, the phone company may not have activated your connection
Dec 30, 2012 | Lands Phones
Tip
How To Reset Your Mobile Phone
You can return your phone to its original state, as it was when it left the factory. This is also called a hard reset. You might want to do this if you are giving your phone to a friend or relative and you want to remove all your data first, or if your phone has a persistent problem that is not solved by powering off the phone and then powering it on again.
A factory reset is a drastic measure. It permanently erases all your personal data and customized settings, and also removes any programs you have installed. Make sure that you have backed up the information and files you want to keep.
As different phone models have its own reset procedure, view complete list here.
on Jul 09, 2011 | Cell Phones
Tip
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
COLORED LINES ACROSS MY IPA SCREEN
you will need to get a new screen. the LEDs are malfunctioning
Dec 20, 2012 | Apple Ipad I-pad
Colored lines appearing from bottom to top of the screen.
the LCD is a very complicating device for all CP. you may check it by disassemble it to it's LCD and connect the ribbon wire/flex of the LCD firmly... but this problem is best to replace it with a new LCD... very complicated device indeed
Jun 03, 2010 | Sony Ericsson w580i Cellular Phone
I have two phone lines one is used for a fire panel other is used for personal use. fire line works, other is not. they were both fine sunday. i've looked at three panels and have counted over eight...
I have a phone with gator clips on it, stoners call them roach clips, thats the way I test my phone lines, sounds like you need to pay the phone company
Sep 10, 2009 | Lands Phones
Can't get the fax to work. It WAS working before.....
follow this simple steps:
1 .Connect the phone cable that came with the printer to the back of your modem to the port that says tele 1.
2 . connect the other end of the phone cable to the port on the printer that says "1-line"
3. connect the phone cable or cord that came with your telephone line to the back of the printer port that says "2-EXT" and the other end to the back of your telephone ..
This should solve the problem..best of luck
Mar 26, 2009 | HP Officejet 7210 All-In-One InkJet...
New phone wire from box to home need diagram to show how to
The phone company should make that connection. Use a phone jack assembly with alligator clips to find the dial tone. The first line color should be a pair, blue&blue-white, 2nd line, orange& orange-white, then green followed by brown pairs which would be 4 line numbers in that color code order. Each line is just a single pair. Thank you. Jer
Feb 25, 2008 | Lands Phones
Phone or fax doesn't work
check there is power in machine. bye
Sep 25, 2007 | Brother MFC-620CN multifunction Color...
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
