Question about Acer TravelMate 2300 Notebook
Travelmate 2300 won't power on
My Acer TravelMate 2300 notebook will not power on under any circumstances.  Does not appear to be charging either.  Will not power on with fully charged battery from another acer.
  • 2 more comments
  • Gonzy Nov 01, 2007
    I have an Acer TravelMate 4150Lci. The AC adapter are good but it shows no sign of power, its been like this for a while so the battery might be deplited by now. I suspect motherboard problem, any other suggestions?
  • Anonymous Nov 19, 2007
    I have dropped my acer 2410..the power lead is live (tested) but no power to unit. Think the power socket is U.S. !! Trying to access the rear to get to power socket..any ideas please. Thanks.
  • Mi4tay Nov 22, 2007
    My Acer TravelMate 4000 will not turn on when plugged into a wall socket. The battery will not charged. It seems the laptop is totally dead. When I tunred it on, it said, 'low battery' and then immediately, said something about going into hibernation. That was over 24 hours ago and it still won't come on. What do I do?
  • frazz69 Mar 13, 2009
    i have a acer travelmate 2300,the ac p.s.u powers on but no power to the laptop.its very dead.lol.
Hi guys, I just received notebook from friend. It is ACER travel mate 2410 - She told me that it was in service but noone could help her and they told that it is dead. As a fool for electronics I check it and found that it is not completely dead - it have just problem with charging - the stick in the middle of charging plug is broken off and need to put it back. Try to look into that hole where you usually put charging cable if there is everything OK - they use there bad plastic material what can broke anytime. Just try to charge battery in any other computer like yours and you will find that it will work when you put charged battery back into your computer.
Posted on Sep 07, 2008
The problem could be your bezel.  Remove the 3 screws from the hinges from the rear and you will be able to remove the black strip above the keyboard (after removing the screws, make sure laptop is layed wide open)  once removed, press the button on the motherboard under where the power button is.  If the unit still does not power up, then your motherboard is bad and needs to be replaced.  If it does power up, you need to replace the bezel.
Posted on Oct 29, 2007
If everything is plugged in correctly and it still will not power on,
follow these steps to complete a ˜power reset' of the notebook.
1. Unplug the ac adapter. Keep ac adapter unplugged.
2. Remove the battery and keep the battery unplugged.
Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
3. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
4. Normally power on the notebook.
If the unit does not power on, remove the ac adapter and insert the battery into the system.
5. Plug the ac adapter back into the system, the battery charging indicator light will light up.
6. If the battery charging indicator light does not light up, the ac
adapter may not be providing proper power to the unit, and may need to be replaced.
Posted on Dec 17, 2007
Acer travelmate 2300, bios password forget, pls can u help me
Not knowing what BIOS/CMOS is on an Acer Travelmate 2300, you can try to see if your chip is supported by the following tool:
http://www.cgsecurity.org/wiki/CmosPwd
I have used this several times, along with other tools by CGsecurity successfully.
Please contact me if you have any questions.
May 04, 2011 | Acer TravelMate 2300 Notebook
How to replace a cmos battery in an acer travelmate 4000
Look at the manual here...
http://www.scribd.com/doc/12027454/acer-travelmate-2300-4000-4500-service-guide-factory-repair-manual-maintenance-sgtm2300tm4000tm4500
RTC battery is what you're looking for....
Oct 27, 2009 | Acer TravelMate 2300 Notebook
250Gb hard drive for Acer travelmate 2300
No. I have tried a 250 Gb but my 2303 wont carry it. it will only recognize up to 130Gb but I did not try it with a 120Gb internally, my 250Gb IDE -HDD will run as an external but there is a power surge warning that comes up when I connect it, however I can run a 500 Gb SATA HDD with out this happening. MURRAY the MAGNIFICENT
Apr 08, 2009 | Acer TravelMate 2300 Notebook
Volume button of acer, travelmate 2300 laptop??
just press and hold key Fn and press arrow up or down to change volume.
Feb 20, 2009 | Acer TravelMate 2303LCi Notebook
My Acer travelmate 2300 usb ports aren`t working
What has changed most recently? did they work before? May be disabled in bios, need more info.
Jan 24, 2009 | Acer TravelMate 2300 Notebook
Acer travelmate 2300 - power on but as if BIOS did not start
Open the memory cover from bottom of the laptop if you can find. And re-plug the memory chips carefully..make sure it be plug in properly. and try switch on again.
Nov 05, 2008 | Acer TravelMate 2300 Notebook
take out the battery and try direct power
May 31, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
1,071 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
