Question about DeLonghi D690UX Cool Touch Deluxe Deep Fryer
How to change the drain tube on a d690ux
None
Ice forming under the freezer drawer & on drain tube water pooling in floor Cleared drain tube, what else?
Whirlpool corp., whom made this unit, had a bad design for the defrost drain tube by the compressor. Order part W10619951 and install. This is a kit to change out the current drain tube to a better one. You still have to defrost the frozen defrost drain tube but this will fix it for good.
Aug 01, 2015 | Maytag MFI2269VEM Monochromatic Stainless...
Looking for the transmission drain plug
There may be none. The bottom cover should be removed to release and change the filter as well when you change the transmission oil.
Jun 23, 2015 | Cars & Trucks
Where is the oil drain plug on this push mower. None exists on the bottom of the engine.
Some engines now being without drain plugs. To change the oil you either need to turn over so it can drain out the fill tube or pump/siphon it out.
I have worked on some MTD tillers that still have the drain but no way of getting to it.
Jun 04, 2015 | Garden
Drain fault
Look for a level sensor tube low on the machine, it may go to a small container or such. Then a signal tube will go to a switch that controls the pump. Check all this stuff for debris, loose connections, etc.
Nov 26, 2013 | Miele W526 Front Load Washer
How do you change the oil? WHERE IS THE PLG?
If there is no drain plug in the crankcase bottom (under deck), then look for a square-head type plug on the engine side near bottom. If none there, then the mower will have to be tipped on it's side and the oil drained out of the oil fill tube.
May 08, 2011 | Kelty Yard King 21" Push Lawn Mower w/...
Door does not have the suction sound and food in front is soft also running none stop
The suction sound is not always to be there.
What causes this is the air is being sucked yup through the vent holes in the door and out the drain tube in the bottom rear of the unit.
The drain could be plugged up or there is water in the drain tube,There should be some water in the tube this is to prevent air from escaping and causing the unit to run longer.
you may need to check the evap coil in the rear of the unit and make sure that it is not frozen over.
Dec 27, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
1993 Chevrolet 2500 Where is the transmission fluid drain plug ?
The automatic transmission has none.You need to remove the pan or syphon thru the dipstick tube.Manual trans has a pipe plug for drainage.
Jan 31, 2010 | 1993 Chevrolet C/K 2500
Model D690UX Delonghi deep fryer
Well I did solve my own dilemma. You have to unscrew the bottom black bolt in the bottom center of the unit. the open up the front panel to reveal a tiny screw just below the top center of the front panel. Remove it. Be very careful and remove the front panel. Pull lightly up on the inner black pot to reveal the clamp that holds the old drainage tube. Using a needle nose wrench, squeeze the clamp together to release the old tube and the clamp. Add new drainage tube inside the clamp and do the reverse. Make sure when you put the front panel back on, the open button's bottom part is inside a little **** or it will not work (it will fall out when you take front panel off). Make sure the little lamp is inside the red ON button.
Et Voila.....all fixed
Sep 21, 2008 | DeLonghi D690UX Cool Touch Deluxe Deep...
DeLonghi D690UX Cool Touch Deluxe Deep Fryer Logo
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
