Erratic cursor ms media centre wireless keyboard
The cursor moves erratically or freezes and then you cant perform any operations at all. switch off/on does not fix. change mouse speed does not fix...PLEASE help. Using MS Media Centre for TV viewing & web activity on same TV screen
    Problem Solver:
  • 11 Answers
What platform? Memory (needed for this sort of task)? WiFi gateway? Model?
Importantly, have you attached any Apple devices to your system recently?
If the connection is Bluetooth (to TV), well, there's not much help for it. You need a lot of CPU and Memory for smooth flow and device functionality.
Posted on Dec 29, 2013
  • Russell
    Russell Dec 29, 2013
    No Apple stuff anywhere, Bluetooth capable but not in use. System Built to cope with needs so Massive CPU & Memory. I think its a software issue.
4 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: Media centre
if you have a TV card and antenna or cable hookup, yes.
Posted on Dec 26, 2007
mewms_14904
  • 1027 Answers
SOURCE: hi, whenever I turn on
The blue screen of death is caused by a problem associated with the drivers for the wireless adapter. It is commonly called a "STOP ERROR"
download and run everest home from this site
click on Network, click on windows network. this will ID the wireless card you are using. google the card for updated drivers.(or e-mail me at mewms_14904@verizon.net
Posted on Aug 22, 2008
  • 220 Answers
SOURCE: Wireless Keyboard not working
try updating the drivers but first try to uninstall and reinstall the sofware for your keyboard and mouse.
Posted on Jun 21, 2009
Cursor freezes or is erratic
Ow, I have had this problem myself. Do you have an iPhone or other Apple device that you've connected lately?
I am assuming your mouse is either Bluetooth or uses a proprietary 'dobgle'...Which?
Dec 28, 2013 | Computers & Internet
Tip
Erratic Keyboard typing on laptop
If you are getting erratic keyboard typing (unexpected cursor positioning), verify keyboard driver is up to date. If it is current, remove the keyboard from the laptop (see other sites for directions, but should be easy). Once removed, clean the ribbon contacts using q-tip and isopropyl alcohol. Dry with clean q_tip and reinstall. This may solve the problem without having to purchase new keyboard
on Apr 01, 2011 | Compaq Keyboard
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Erratic behavior of MS wireless optical mouse
Your wireless mouse the battery might be low, change the battery and go to control panel and click the mouse icon, and adjust the right mouse speed setting.
hh
Jul 27, 2009 | Computers & Internet
Hyper senitive & erratic mouse
reinstall the driver for the mouse and see if that fixes it.... also you can try going to control panel----mouse and the changing the settings... you may have to experiment abit to get it the way you want it.
Robert
Please take a moment to rate this solution... thanks
May 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Cursor freezes or is eratic
I believe this would be caused by a couple of things. The first, and most likely is probobly that it needs a driver update. If this is not the case, go to computer properties(Right click 'My Computer', then hardware (if xp) then device manager. Go to pointing devices and uninstall the mouse driver.
Yes, you will be unable to control ur laptop. Simply turn off and then the computer will recognise the maouse/mousepad and install the driver.
The second problem could be to do with a nasty little bug out there thats causes both your curser and/or keyboard to act erraticly.
May 19, 2009 | Acer Aspire 5520-5908 Notebook
DELL Dimension E510-mouse erratic, usb pop ups
Did you check to see if your type mouse is compatible with your unit and your operating system? (XP or Vista?)
Jan 05, 2009 | Microsoft WHEEL OPT USB PS2 3 Button...
POINTER FREEZES THEM MOVES THEN FREEZES DRIVING ME NUTS. THANKS
When this behavior is observed when using a Logitech product withinWindows® XP, it may be caused by a feature within Windows called"enhanced pointer precision". This feature may conflict with Logitech's software, causing the erratic movement. Enhanced pointerprecision became available in Service Pack 2 and therefore is notapplicable in any version of Windows® XP without Service Pack 2installed. For more information on enhanced pointer precision,please click HERE. If this link does not work, then you should go to Microsoft and search for Knowledge Base article 895550.
Please see these articles from the Logitech database for possible troubleshooting tips as well:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=970
Troubleshooting: Erratic Cursor Movement in Optical Mice and Trackballs
Mouse cursor is uncontrollable or behaves erratically
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Interference with Cordless Products
Download latest version of software
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Nov 27, 2008 | Logitech Cordless Mouse
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Labtec wireless desktop.
Could be radio interference from somewhere. I tracked my similar mouse problem down to emissions from the ethernet adapter that connects over the house mains wiring. Try the using the mouse close to the receiver, if it works ok interference is likely.
Jan 24, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
