Question about Vehicle Parts & Accessories
Replaceing all motor mounts on a 2002 pt cruiser
How to replace all motor mounts on a 2002 pt cruiser
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You need a front wheel drive engine lift to replace them all at the same time or a floor jack and some lumber and do them one by one... But if you need actually instructions on how to do it, I feel as if it's unsafe to give you than info...
Posted on Dec 29, 2013
How do change the motor mounts on a pt cruiser?
Ensure the quality of the mount. Also check the dynamic balancing of the engine, propeller shaft and the center bearing.
Aug 29, 2014 | Chrysler PT Cruiser Cars & Trucks
Torque converter switch lockup
I have a 2002 pt cruiser I re ringed the motor because it ran a little warm now that I replaced every thing I cant get it to start again ...
Oct 05, 2013 | 2002 Chrysler PT Cruiser
My 2002 pt cruiser won't shift out of low.
the 2nd & 3rd gear solenoid needs replacing. It is mounted by the trans filter inside the trans pan
Jul 27, 2010 | 2002 Chrysler PT Cruiser
Replace EGR valve on a PT Cruiser
The valve is located just above where the engine and transmission seam meets. There is the metal exhaust gas tube with 2x8mm bolts and a fiber gasket. The EGR mounts to the cylinder head with 2 10mm bolts and a metal gasket. There are 2 vacuum lines that go to the control solenoid, a black plastic pod moounted under the throttle body. It clips into the TB mounting bracket, and has a 3rd vacuum supply line and 1 electrical connector.
Sep 14, 2009 | 2002 Chrysler PT Cruiser
I have 2002 pt cruiser Put new upper and lower
IT SOUNDS LIKE THE MAIN MOUNT IN FRAME ON PASS SIDE IS BROKEN..I HAVE NEVER SEEN ONE BROKEN BEFORE OR REPLACED ONE,BUT IT WOULD A FAIR JOB TO REPLACE..ALSO THE BOLT THAT GOES THRU FROM FENDERWELL MAY BE BROKEN..CAUSING YOUR PROBLEM..THERE IS A SMALL PLASTIC PLUG IN FENDER WELL..ABOUT AN INCH OR SO IN DIAMETER..THERE IS A TORX BOLT(T55)IN BEHIND PLUG..CHECK AND SEE IF IT'S NOT BROKEN..TRY TIGHTENING OR LOOSENING IT..IT MAY BE BROKEN OFF IN PLATE THAT IS BOLTED TO ENGINE..LET ME KNOW WHAT YOU FIND
Sep 08, 2009 | 2002 Chrysler PT Cruiser
Motor mounts
Most motor mounts are basically a piece of rubber attached to a piece of metal. Rubber just dries out after time and begins to crack off. Accelerating hard can speed up this process.
Aug 21, 2009 | 2004 Chrysler PT Cruiser
04 PT CRUISER HAS BUSTED MOTOR MOUNT. WHAT IS THE ESTIMATED REPAIR COSTS AND PROCESS OF REPAIR.
Theirs more than one mount and they cost 60 -125 at a parts store Most fair mechanics will just change the front one and send you down the road for less than $200 for one mount. The dealer will reconmend them all and their right if over 100 thou miles and get out $500-800
Aug 15, 2009 | 2004 Chrysler PT Cruiser
Describe your 2002 Chrysler PT Cruiser timing
Replace the belt at 100k with a new water pump pulley and tensioner. It would not be a bad idea while u r in there to replace the center motor mount. When the mount fails it is a pricey fix not a bad Idea to replace it since you have to remove it to do the belt.
Jul 04, 2009 | 2002 Chrysler PT Cruiser
Pt cruiser aerial
At the base of the antenna, take a small crescent wrench or pliers and unscrew the antenna from the mounting bracket. Any Chrysler dealer should have a replacement antenna.
Oct 06, 2008 | 2002 Chrysler PT Cruiser
Vehicle Parts & Accessories Logo
56 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
