Question about Hampton Bay 40093 Tripolie Ceiling Fan
I only need the smokey colored globe about 3-4inches across
I don 't want a ceiling fan, only a globe in smokey color. I have the two other smokey color globe
  • 16 Answers
SOURCE: The globe for my Hampton
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Posted on Jan 21, 2009
SOURCE: I'm tring to find a light globe for may antigua
I am thinking of buying this fan, but do not want to use the light. Are you still looking for a light globe?
Posted on Mar 25, 2009
  • 1019 Answers
SOURCE: Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Posted on Jun 15, 2009
SOURCE: replace globe
i need a new globe mine broke how can i get one?
Posted on Jul 28, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: i need to know what wire color goes on what wire,
The distribiution of the wiring normaly all the black wires should be connected to a black wire line, before the switches, then each switch individually will activate iether the lights or the fan motor.
Posted on Jan 06, 2010
Wire colors are not the same as original capacitor Voltage rating is the same. 3 wires on one end 1 wire on other. Does the color matter or should I wire it in the way it was regardless of color.
I'd use an analog ohmmeter to test both of them to see if they are wired the same. The meter needle should jump, and go back to zero if the meter leads are across a capacitor.
Jul 03, 2015 | Other Ceiling Fan Capacitor 1 - 4 mfd 4 uf...
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
The globe for my casa vieja ceiling fan broke. where can i buy a new one? how do I measure the size to know what I need?
You can find replacement globes at most lighting or building supply stores. The dimention you need is the diameter of the circle that the globe sits into.
Apr 30, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
Need instructions to fix ceiling fan - Hampton Bay 55295 + remote
if you tell me what colors of the wires you have on the fan y what colors of the wires on the ceiling may be can help you here is my E-mail: mhernandez781@hotmail.com.
have nice day
Jul 15, 2009 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Need new globes on lights
Go to lowes or home depot as both places carry replacement globes in stock. They can also special order for you. Bring in one of the old globes to be sure you get a perfect fit.
Apr 28, 2009 | Westinghouse Helix 78794 Chrome Finish...
Cant remove Globe to change light bulb on Hampton Bay ceiling fan
twist counterclockwise (looking up at it) on glass firmly and carefully, the globe functions like a screw
Mar 28, 2009 | Hampton Bay 24002 Ceiling Fan
I'm tring to find a light globe for may antigua ceiling fan mine broke when tring to take down form ceiling. where can i find one?
Feb 28, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Replace globe
Jan 05, 2009 | Hampton Bay 40093 Tripolie Ceiling Fan
Globe broken on Aloha Breeze 52" Satin Nickel - need replacement
try a hardware store, lighting store home depot. You'll likely find the globes are standard size.
You could also try Aloha Housewares 1-800-295-4448 9am - 4pm CST (Closed from 12-1pm)
May 21, 2008 | Aloha Housewares (93645) Ceiling Fan
Hampton Bay 40093 Tripolie Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
