Question about LuxPro PSP711TS Touch Screen Programmable Thermostat
Reset air psp511lca
The thermostat is stuck in change filter mode
    Habit-Forming:
  • 188 Answers
Page 6 shows how to reset filter light. http://www.luxproproducts.com/pdfs/PSP711TS_NL_ENG_Manual.pdf
Posted on Dec 29, 2013
How do I deleate the change filter light?
My model is the psp511lca but it may be the same type of reset. I have a dial I turn to the "change filter" option and then press the up and down temperature buttons simultaneously and hold for a few seconds. When you turn the dial back to "run" the change filter light on the display is gone.
Sep 12, 2014 | LuxPro PSP711TS Touch Screen Programmable...
Reset air psp511lca
To reset the air filter indicator:
1. Open up the control panel and turn the dial to "Air Filter"
2. Press the temperature up and down buttons simultaneously
3. Turn the dial back to "Run"
If you forget these instructions, you can find them in the owner's manual. You can download the manual here:
http://www.luxproproducts.com/pdfs/PSP511LCa_NL_ENG_Manual1.pdf
Dec 28, 2013 | LuxPro PSP711TS Touch Screen Programmable...
Lux TX500e thermostat
go to honeywell it,s a house hole name
Nov 07, 2013 | Lux Tx500 Series Smart Temp Electronic...
I bought a brand new house and the gas water heater seems to be stuck in vacation mode.
Copy following link to troubleshoot by type of gas control valve, instructions how-to-light-water-heater, including error codes etc:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
To reset the intellivent gas control, press and hold both arrow buttons for about 5 seconds
This water heater requires pilot flame. Look through site glass and upward (or use mirror) to see if pilot is ON and burning clear blue flame and not lazy yellow flame.
Check that gas shut-off is parallel to gas line:
http://waterheatertimer.org/images/Gas-water-heater-89-valve-2.jpg
Check if outlet has 120Volt, and that polarity of outlet is correct. Power vent water heaters require correct polarity: use circuit analyzer. Check if there is ground continuity between ground and manifold tube (center tube that connects between burner and gas control valve).
Scroll to top of same link to read about FV system and air intake cleaning. Must have good supply of incoming air.
Same page half way down has troubleshoot section for pressure switch testing, blower troubleshoot etc. The pressure switch and blower communicate electrically with gas control thermostat to determine when to release gas to burner where pilot ignites gas, causing poisonous combustion by-product to vent outdoors and help nature.
This model has thermopile instead of thermocouple. Basically thermopile is several thermocouples. When heated, thermopile generates enough current to run small electronic circuit inside gas control valve. This circuitry is very common in hvac units but fairly recent to water heaters. Advantage is error code troubleshoot and more optional controls, for example future response to in-home zwave remote controls and home automation
Get model number and brand from label on side of tank and post question on pro water heater forum with list of what you have tried so far.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Call plumber to bleed air out of gas line and check gas pressure.
May 28, 2013 | Water Heaters
Snowflake symbol on thermostat
Copy following link for Lux product manuals
http://www.luxproducts.com/instructionmanuals.php
It might mean that AA batteries needs to be changed.
Or it might mean 2nd stage heating cycle.
Air filter needs to be changed.
Tech assistance 856-234-8803
Oct 26, 2012 | LuxPro PSP711TS Touch Screen Programmable...
How to reset filter indicator on luxpro psp511lca
RESET FILTER COUNTEROnce you have replaced your filter, the filter life counter is reset back to its fullamount remaining value by turning the dial to AIR FILTER and pressing the UPand DOWN buttons together at the same time. NOTE: The counter is also reset bychanging the filter setting value, as described above, to a different number ofdays.
Jul 17, 2012 | LuxPro PSP711TS Touch Screen Programmable...
Reset button will not reset, stuck in place
Best solution would be to change out the thermostat it could cause problems if by chance you do get it to reset. Something goes wrong and it want trip the reset it could cause a fire, so the safe thing to do change it out.
Oct 23, 2011 | RELIANCE ELECTRIC WATER HEATER
How do i reset my thermostat on my whirlpool gas water heater
On some models there is a thermal reset at the bottom to the right of the viewport, between two wires. The wires can either be two white and or one white and one black. It is a small white button. If it continues to trip you might want to check the air supply. Can check air supply by doing a draft test. And make sure the air filter at bottom of the heater is clean and free of any obstructions. Hope this helps.
Aug 31, 2009 | Whirlpool Water Heaters
Central haeting keeps turning on when itself
Change your air filter, if the system has to work too hard, it will over heat. If the filter is allowing air flow and the system still shuts off it is the thermostat. Keep in mind the Thermostat gauges the temperature where the thermostat is located, if its next to a running fireplace it will think your entire house is that temp.
Feb 02, 2009 | Water Heaters
LuxPro PSP711TS Touch Screen Programmable Thermostat Logo
245 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
