AOC Monitor says "no signal" and won't wake up!
My AOC F19 monitor is only two months old and has worked fine. But yesterday, when attempting pushing the bottom part of the button (hoping to turn down the brightness, but not having a manual, I wasn't sure what I was doing), it went to sleep and won't wake up. When I turn it off and then on again, it says "no signal" and then immediately the yellow light goes on again, into sleep mode. I can't wake it up. It's connected to a Mac Mini. I have unplugged and replugged every cord I can find, but still it sleeps on. I've turned it off and on multiple times. I've pushed the button (while yellow light is on) multiple times (hopefully not messing it up more!). Help! -- Lindsay
    Novelist:
  • 118 Answers
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
Posted on May 19, 2009
  • odaye_deluxe
    odaye_deluxe Aug 19, 2012
    i did what you recomended and it worked but then after a couple of days the same problem occurs. also when on the internet the screen goes blank. i checked for viruses and there seems to be none how do i get this from reoccuring
Aoc e2243fw no signal
check for loose contact at the VGA port or replace VGA cable. if won't work, check for bad component parts at the lcd controller board like open resistance or replace the board will solved the problem.
Sep 15, 2012 | AOC e2243Fw 21 inch LCD Monitor
AOC color monitor model 9g1rs, dead, ** volt, fuse good
Hi
You need to replace HOT(Horizontal Output Transistor) see number carefully before you replace it.
Mar 14, 2008 | AOC CRT Monitor
I have an AOC e2243Fw series monitor, less than 2 months old. i recently moved my computer from one room to another. Plugged all the cables in. My cpu works fine, but m monitor is telling me no signal. I...
You have problem with computer. Is you video card is built in. if not reset the video card of your computer. Full it up the card and return i again to the socket. Then check your monitor.
Sep 08, 2011 | Computers & Internet
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Chris
Jul 08, 2011 | Computers & Internet
I JUST BOUGHT A NEW AOC F22 MONITOR, BUT IT GOES BLACK , THE POWER IS ON YET I CANNOT SEE ANYTHING, HOW CAN I SOLVE THIS PROBLEM?
If the monitor is black either the computer is not sending signal to the monitor or the monitor is getting the signal and its broken.
1.) does the old monitor or another monitor work with the computer you have. if yes your monitor is prolly broke since there is not much to a monitor they automatically detect signal as soon as its turned on.
2.) if the monitor doesnt work the old one then your computer is the issue and it can be a lot of things can cause no video
Mar 03, 2011 | AOC F22 Monitor
No power in the Monitor
Sounds like a fairly drastic fault, possibly in the power supply section. Probably not worth fixing with the cost of new LCD screens, but maybe worth asking at a local repair place.
Apr 06, 2010 | AOC 7F 17" CRT Monitor
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
AOC LM729 17" LCD Monitor
the inverter needs to be replaced
not real hard, but must have some knowledge of the process
Feb 02, 2008 | AOC LM729 17" LCD Monitor
Computers & Internet Logo
4,781 people viewed this question
David Payne
David Payne
