Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsu 46805 - No picture
Turned the TV on today - still receive sound, but there is not picture.
Cannot pull up a menu or anything.
Any advice?
  • 143 Answers
This model has loose connections on the yokes remove the front speker gril and a small cover wigil the wires alittle and see if the pic comes back on if so solder the bad connections and put fresh solder on the verticl ic too
Posted on Nov 04, 2007
Yamaha HTR-5063 is connected with new LG smart TV with HDMI. Today no picture or sound on TV. How to fix it ?
First, you need to identify which box the problem is in. Does the TV work with other inputs? If not, problem in TV. If it does, then the problem is in the Yamaha.
Once you know where the problem is, you can proceed to fixing what's broken.
Jul 10, 2015 | Yamaha HTR-5063 Receiver
No Picture or Sound on LG 50PK950
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 01, 2013 | LG Electronics Infinia 50pk950 50 Inch...
I have just bought an LG LED LCD 3D TV (model 42lx6500). I bought it yesterday and today I lost the picture, but still had sound. Turned it off and turned it back on and now I have no picture or sound! I...
WOW we bought 2 of those tv,s..... 1 from sears and and had lines through the centre.. took it back and went to future shop and bought the same. within hours of turning it then off and back on the tv would not work. woud act like the remote was being used and it was on the table. took it back and bought a sanyo... no more problems...
Nov 21, 2010 | LG 32LC7D Television
No TV Picture
Unplug,replug an hour later,might reset to factory setting.Tries stop all timer setting.
Dec 29, 2009 | Televison & Video
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Half Dead mitsubishi wt-46805
This condition can be caused by multiple failures, however this unit has chronic bad yoke connections. Difficult repair for a layman but not for a tech or shop. Most likely 200 to 250 for that repair. Other more serious failures sure to cost more.
Feb 09, 2008 | Mitsubishi WT-46805 46" Rear Projection...
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
91 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
