Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Freezer will not shut off some things frozen, bread and ice cream soft
Some things freeze, ice cream and bread soft, freezer will not shut off. what is the problem
    Sergeant:
  • 236 Answers
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Posted on Jan 04, 2014
huuum
  • 750 Answers
SOURCE: Sears Kenmore Deep Freezer settings
It sounds like you have a circulation problem.
Spread out the packages so the freezing air can circulate.
  • Check that the condenser fan is on
  • Check that the coils are not covered with lint and dust especially if they are under the freezer.
  • you may need a tech to put freon in the system.
Posted on Apr 07, 2009
  • 3 Answers
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Posted on Jan 21, 2010
  • 152 Answers
SOURCE: Ice cream and Cool Whip are soft but ham/chicken are hard
Freezer is not cold enough probably holding about 20 degrees. Try setting your temperature up for the freezer if that doesn't help you may have a problem that needs service.
Posted on Feb 14, 2010
mreid542
  • 166 Answers
SOURCE: Everything in our freezer is frozen solid except
If this is a self defrosting model make sure that you don't have frost build up on the back wall of the freezer causing the air not to circulate like it should. If you do have frost build up other items will eventually start thawing as well. If this is the case you have a defrost problem.
If this is not a self defrosting model then make sure it does not need defrosting.
You normally will notice ice cream being soft before you notice other things thawing.
Also make sure the door is shutting good and you may try putting the ice cream in a different location.
Posted on Jul 20, 2010
heatman101
  • 43501 Answers
SOURCE: meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
What can I do to get the ice cream to be frozen?
It might be a good idea to clean the condeser coil. If the coil is blocked, your freezer will not get cold enough.
Jun 03, 2014 | Sub-Zero Freezers
Frigidaire LFFU14F5HWH Not Completely Freezing
Maybe It Needs Regasing Some Fridges Have a Swich Between The Fridge And Freezer If They Are Fan Forced That Gives Off The Same Symptom As Being Out Of Gas Or Low On Gas
Nov 06, 2013 | Frigidaire FFU14F5HW Upright Freezers
Everything in our freezer is frozen solid except for the ice cream which is soft and mushy, the freezer is only about 3-4 years old and we checked and it is turned up to the coldest setting, any ideas what...
Jul 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
One side of freezer has stopped freezing... bottom is not frozen
You have either got a blockage in the system or there is a leak. My bet it is a leak. Seen this many times on the whirlpool.
May 28, 2010 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Amana BR18 fridge/freezer. Fridge is cool but not cold, freezer is at about 20 degrees. Ice cubes are frozen but ice cream is soft. Any ideas?
you maybe blocking the circalation in the freezer the way you have things packed in there. Move large items away from where the cold air blows in.
Oct 04, 2009 | Freezers
Freezer not freezing
not freezing icedraem is an issue, bread not so much, different breads contain different ingrediants that may or may not freeze, forst offthough wher is unit located??? in garage??? if so be aware that it may not operate efficiently ion ambient temps lower then 55 degrees, but if this is in your kitchen i would suspect a "refrigeration"/sealed system issue, perhaps "low on charge and not able to maintain a frozen set temp. Meat may stay frozen ( for a little while anyway, but the ice cream is the first to show indications of problem
Jan 11, 2009 | Freezers
Meat is frozen but ice cream is soft
heatman101
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
Freezers Logo
140 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
