Question about Graco Pack 'n Play
One side rail of the graco is frozen how do i release it?
How do you disassemble the top rails to remove the lining for washing?
Pack 'n Play® Playard with Newborn Napper ... - Graco
www.gracobaby.com > Home > Playards > Care Station Playards
GracoGraco Pack 'n Play® with Newborn Napper® DLX grows with your child as you ....since it was very easy to assemble and the instructions were easy to follow.
Sep 17, 2015 | Graco Newborn Napper Pack and Play Playard...
2002 Graco crib instructions . i bought a used 2002 crib and I need to know how to put it together.
ok first thing first ,  some graco cribs and other products from 2002 -2010 are being recalled , so what crib model do you have? second , putting together a crib is very easy , . First , take the head board and stand it up , next find the side railings and one by one put the screw thru the rail and into the headboard , hold it in place untill it is where it needs to be , then put the second railing on , the screws should go thru the rail and into the headboard with the headboard in back of the rails, after the rails are secured then hold the foot board in place untill the screws are fastened into the rails as well , after you do this , then go around and make sure all the screws are tightned, then take the mattress spring and place it inside the setup rails and screw it unto the places alotted for the screws , then after this , place the matress inside and your done....if this doesnt help , please email me at konmon52@aim.com and tell me which model it is
Nov 19, 2010 | Graco Baby Gear
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
How cani open graco play pen
To open the Graco Pack 'n Play from the folded position, you have to latch each side rail by pushing the two ends of each rail until they are horizontal and form a straight line. They will latch into place with an audible snap -- do this for each of the four sides. Then push the center of the Pack 'n Play's floor down until it is flat as well.
If you can't latch the side rails, the floor of the Pack 'n Play might be down too far. Push the floor up until its center reaches at least halfway up the sides of the Pack 'n Play. (You can do this by pushing the sides of the Pack 'n Play in toward each other.)
Were you able to open it using these instructions?
Jun 24, 2010 | Graco Pack 'n Play
Graco 3-in-1 crib instructions
Check this CPSC link.
Most if not all of the simplicity brand cribs have been recalled reguardless of whether they had wood or metal mattress supports.
There were 2 different recalls on the wood version but both were recalled for the drop-side issues.
This link specifically includes the Aspen 3 in 1 cribs and model #: 8740
We took ours to our local walmart last summer (we purchased it in a different state almost 8 years ago). I brought to cpsc report with me. They had not issue with the recalled information we has matching it to our crib. It did take the clerk a bit to find our crib in their system because it was older, but once she did we recieved a full refund, without a receipt.
As far as changing them to a toddler bed. When we converted ours to a toddler bed we simply removed the drop-side from the crib. The drop-side parts can be unscrewed from the side rails. Then we screwed the toddler rails to the bottom of the crib. Ours had screw holds for the toddler rails on the mattress support. If you do not have the holes for it, then you may have put the mattress support on backwards ie with the side that has the holes for the toddler bed rails on the backside of the crib.
Dec 04, 2009 | Graco Apsen 3-in-1 8740 Crib
I need instructions to assemble a graco lauren 4in1 convertible crib expresso i have all the parts just no instructions can you help
I need instructions to re-pack my Packn Play. It has a changing table and a bassinet. It was all packed together when I got it . Now a month later and my grandaughter's visit over I can't re-pack it HELP!!
Aug 15, 2009 | Graco Lauren Crib
Drastic Need for 2 Upper Tracks...
if you have the conversion kit for the crib to convert to a toddler bed, you should also have the white caps that go one the end of the guard rails for the toddler bed. I found with mine that they are the same ones as that are on the stationary side of the crib on the back side. if you do not mind having a crib with out a drop side you can remove both tracks and take those pieces and make it a stationary crib by merely following the way the rear side is put together. I have done it with mine as a guide was broken on mine. there should be four caps in the conversion kit that go on the two rails on the front side when you convert to a day bed. I figured out that they are the same as the ones on the back because you do actually use the ones off of the back side when you make it a toddler bed and put all four rail on.
Aug 15, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Graco Pack 'n Play Logo
Top Graco Toys Experts
Shehu Pro
Shehu Pro
ray gallant
thegtw
Are you a Graco Toy Expert? Answer questions, earn points and help others
