Question about Chamberlain Clicker Universal Remote Control KLIK1U
Garage door goes up but not down with remote - Chamberlain Clicker Universal Remote Control KLIK1U
Sears craftsman 1/2 hp. Door goes up with remote, but when button pushed to go down the light flashes and door doesn't move. If you push the wall mounted switch, the door goes down like normal. Works...
Check the sensors in the doorway. They should both have a small light that is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have 2 problems with my Craftsman Garage Door opener: 1. I have a 2 door-garage & 2 remote controls Both remote controls can open one garage door (since they were originally programmed). They...
I can't help you on programming.
If the door goes up as soon as it touches down, it is going too far down.
Locate the adjustment on the box on top. There should be four adjusters:
Door down amount more or less
Door up amount more or less
Force down more or less
Forch up more or less.
Turn the Door down amount toward the "LESS" or "-"
Let me know how you do.
Gary
May 31, 2011 | Garden
Sears technical support for craftsman products- Will not work with car and remote. Goes down with internal contol, but goes right back up. Tried resetting it fro car and remote, with no results
Sounds like you have a couple problems. The remotes not working is probably the logic board. The door coming right back up is either the door sensors misaligned or the door is traveling too far and hitting the floor.
Jan 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Worked great the past 2 years. Now, garage door
Remove the cover and take a look at the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Jul 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door goes up, but will not go down. i push the opener
Make sure the door sensors are aligned properly. They must be pointed at one another and the small light on each one should be lit and not flickering.
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Clicker Universal Remote Control KLIK1U Logo
44 people viewed this question
Top Chamberlain Home Security Experts
Norm Pearl
Tom Chichester
Bill Boyd
Are you a Chamberlain Home Security Expert? Answer questions, earn points and help others
