Question about Pioneer TS-W3004SPL Car Subwoofer
Wire 2ohm or 4 ohm
How do i find good working guides and manual for wiring 3 subs TS-W3004SPL. I don't know if it's best to have them in 2ohm or 4 ohm or 8ohm?i need to look at different solutions! :-D All help appreciated. :-D
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 95 Answers
Wiring depends on what amplifier you're using..
Posted on Feb 06, 2014
2 Suggested Answers
sticky92505
  • 77 Answers
SOURCE: Wiring diagram for Pioneer TS-W3004SPL subwoofers
a good resource for wiring and information on the web can be found at 12volt.com
Posted on Feb 18, 2009
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
NOT SURE WHAT OHMS SUB I NEED!
if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
I have 3 alpine type r 2 ohms each and hiffonics brutus 1500
Assuming that when you say 2ohm you mean that both coils on the subs are 2ohm. If this is true then wire the individual subs in series to make 3 4ohm subs, then wire 'em all together in parallel to your amp so your amp will run at 1.333 ohms, and your subs will see about 400watts rms a piece, because wiring it at 1.333 ohms reduce output by about 20% but this is the best you're gonna get w/o going under amp's stability which is highly unrecommended. Besides those puppies'll still slam hard! Hope this helps...
Sep 16, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
I have 2mb quart 15's 2ohm sub and a hifonics bxi1608d amp
The two 2ohm subwoofers can only be wired to a 2ohm or 8ohm load. You are gonna want them wired 2ohms on a monoblock amplifier. the other option is to wire each sub to 4 ohms (series) and then connect each one to a separate channel on a 2 channel (stereo) amplifier. go for an amplifier that produces up to the MB's RMS rating and make sure they are enclosed in a box to their specifications and they should pound.
Jul 30, 2008 | Jl Audio 500/1 Car Audio Amplifier
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Pioneer TS-W3004SPL Car Subwoofer Logo
87 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
