Question about Microwave Ovens
I have an older Kenmore gas stove The oven - Microwave Ovens
I have an older Kenmore gas stove The oven recently started making a humming sound while heating up The volume of the hum varies it is like a vibration noise Any idea what is causing this and how we can fix it
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Fan replace
Posted on Dec 28, 2013
SOURCE: Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Posted on Dec 31, 2009
SOURCE: loud humming/no heating
ck door swicth
Posted on Apr 07, 2007
SOURCE: noisy when running - not the usual humming noise
check turntable motor or bush, this very easy problem, you can use oven no problem..
Posted on Nov 13, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave makes a strange humming
Assuming nothing's loose (such as from past repair attempt) then it may be the magnetron failing.
Your best bet is to keep using but (as always) do not leave it unattended while it's running.
Then if things get worse in some way, that would be a harder failure that can be assessed more easily.
If you are close to the end of the warranty period (1 year parts & labor or 9-year magnetron, e.g.) I would not wait past then.
GE Customer Service is here if you would prefer service now and want to find your nearest GE-authorized servicer.
Posted on Oct 20, 2008
  • 38 Answers
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Posted on Mar 20, 2009
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
Apr 19, 2012 | GE JE1660 Microwave Oven
Oven will not heat up. The Oven igniter glows but the gas pipe does not light up. The broiler gas pipe at the top of the oven lights and so does the stove top burners. Do I need to replace the Flat...
Microwaves use a magnetron to emit the waves, they make a very characteristic (and loud) humming sound when they 'kick-in.' If it is not making this sound that's your problem. It is not a user-replaceable part so please take it to an appliance repair shop, or purchase a replacement (which will probably be the same or lesser cost than repair unfortunately.)
I hope that this will help in solving the problem....
Aug 08, 2011 | Microwave Ovens
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Makes a humming noise wont heat
If its making a humming noise, that means the diode is bad and should be replaced. Once replaced the microwave will begin to heat again.
Feb 11, 2011 | Kenmore 62622 Microwave Oven
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
My microwave kenmore 66222500 makes a humming sound like if it was on when the door is closed. i have to unplugged it or leave door open to stop the humming sound. I tested the magnetron, the primary and...
Possibly a shorted relay on the main timer board?? hum coming from transformer being powered with no fan running. With No fan you can hear it hum. shorted power relay on main board.
Jul 28, 2017 | Kenmore 68361 Microwave Oven
Dec 31, 2009 | Kenmore Microwave Ovens
Not heating and making a loud humming noise.
you have done well out of the oven . it sounds that certain components are well worn and probably no able to get parts best advice it time to buy a new one
Dec 21, 2017 | Kenmore Microwave Ovens
Noise/humming while cooking; especially popcorn; intermitent on other food
Popcorn is heated by a metallic insert in the bag. This causes some additional power consumption by the magnetron. It is no cause for alarm.
Dec 19, 2007 | Kenmore 80412 Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
