Question about Electrolux EI23BC51IS
Door mullion flips to a 90 degrees and the door hits left side and will not shut
    New Friend:
    Problem Solver:
  • 11 Answers
Odds are the hinge base slid down. You can raise it up and tighten the screw.
Posted on May 17, 2014
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Any way to adjust the left hand door higher as the centre mullion no longer engages with the bracket that is supposed to make it pivot as the door opens and closes
the plastic bushings may have worn and need to be replaced, but you could try to place some washers on the bottom of the pivots to raise the door
Oct 17, 2009 | Maytag MFI2568AE Side by Side French Door...
Inside wall warm
Possibly the Mullion heater which keeps the door gasket from freezeing when the door is shut and humidity is high.
Oct 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The outside middle front & left hand side of the fridge were hot
The reason you feel heat by the middle of the door is because of the "mullion heater' or anti-sweat.
Check the temperature of the freezer, must be below 12*F for the ice maker to work.
Apr 23, 2009 | Kenmore Refrigerators
GE Side by Side Fridge Door Adjustment
Most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work. make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Jul 02, 2008 | GE Refrigerators
UNLOCK STOVE DOOR
no code for unlockin door, were you self cleaning unit prior to door locking? if so themal fuse problably tripped off for percieved saftey reasons( thought it got too hot), you might be able to jimmy door open witha wire hanger bent a 90 degree angle maybe 2 in long slide it between console and door latch should release to the left. good luck fishin!!!
Feb 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Put back smeg oven door
Yeah I was stumped with this for a short time as it isnt imediately obvious.
The bottom of the two brackets has a flip up catch, place these in the upright position and with some force hook the upper bracket into these catches (please ensure you keep your face and hands away from the direction of the spring)
Once you have the two brackets held open offer up the door at exactly 45 degrees (notice the notch on the underside of both lower brackets) locate this notch on the door hinge hole studs.
Once this is done and your certain it is in the correct postion lower the door from 45 degrees to 90 degrees, put some pressure on the door slightly past 90 degrees and carefully fold down the flip up catches that are holding the upper brackets.
Jan 28, 2008 | Smeg SE250XUK Stainless Steel Electric...
Electrolux EI23BC51IS Logo
154 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
