Question about Flotec Plumbing
Diagram of shallow well system - Flotec Plumbing
Need timing mark diagram 1962 chevy 235 /6 cyl engine on flywheel
The timing marks on that engine can be found on the vibration damper/pulley, on the front end of your crankshaft. It might be just a shallow v-shaped mark on the first pulley, closest to the engine with a pointer mounted on the block. Aligning them will give you top dead center position of your #1 piston.
Feb 26, 2015 | Chevrolet Cars & Trucks
How do I replace the bearings ? can I get a manual on this ?
Yes you can get a parts diagram, a manual(usually downloadable version) At ultitech.com then select: parts/ manuals /schematics.
May 11, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Stereo doesnt fit
At
www.reliable-store.com
get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs, error codes, everything.
Mar 01, 2018 | 2006 Toyota Corolla
1967 evinrude sport 4 60hp wiring diagram
That came with either battery or magneto. If the distributor is rather shallow and the ignition wires cross the middle of the cylinder head, it is battery, if the ignition is long and the wires cross above the thermostat housing- it is magneto.
That is one of the great historic motors made, but carry lots of gas!
Dec 12, 2011 | Clymer EvinrudeJohnson Outboard Shop...
Vac gets stuck in deep end and can't get to shallow end
What type of pool do you have? These specific pool cleaners are made for flat bottomed above ground pools. They are not made to move from deep end to shallow end. If you are using this on an in ground pool that has both shallow and deep or a dished above ground pool, you are not going to get accurate cleaning.
Mar 06, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Can a shallow water pump be converted to a deep water pump?
No, if it is a true shallow well jet pump it may not be converted to a deep-well. A deep well may be converted to shallow well.
I hope this may have helped,
Tom
Sep 21, 2009 | Plumbing
Doesn't clean shallow end
try aiming the return ports to direct the cleaner to the shallow end
Jul 31, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Plumbing Logo
53 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
