Question about Casio Cameras
Casio camera no display
On power no display only black picture
  • stressed6161 Dec 30, 2013
    Hi joel maureal, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Like answering some dumb questions. Are the batteries in right and in good condition, stitch in on position, does it work with power adapter? What type of camera is it?
  • joel maureal Dec 30, 2013
    Hello stressed6161, battery are ok. power on are good and display all menus. but no picture/objects direct from the lens. shutter no function. It is CASIO EXILIM DIGITAL CAMERA.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Does the lens move when you power it up, it should have a built in lens cap make sure it is moving out of the way. If these are OK then the only other thing is the internal photo cell isn't detecting the light. How old is the camera & did it get dropped? Did U get an extended warranty. U may be talking about a lot of $ to repair if that is the problume.
Posted on Dec 31, 2013
2 Suggested Answers
  • 94 Answers
SOURCE: When I take a picture, the display and picture are black.
The shutter is jammed shut, lens unit needs to be serviced.
Posted on Jun 10, 2010
My screen is all white
First verify that you didn't just accidentally turn off the LCD. To check, turn the camera on and press the "DISPLAY" or "DISP" button once. One other thing to check is that faded pictures can sometimes be caused by a stuck shutter. Potential symptoms may also include purple scratchy lines showing up on the LCD monitor and the camera's pictures. Other reported symptoms may be extremely distorted images (one reader likened them to the movie "Grudge"). Or blank or black pictures or black videos with good sound being recorded on the camera's flash card. You may suspect that the camera's shutter is not opening, but this is not the case. Note that the camera's menu functions should show up without any problem. Please note that your camera must be experiencing these symptoms due to a faulty CCD, and not due to other problems. Note that they're going to look for dings and dents. This is a CCD failure and in some cases had been subject to a recall. Contact Casio support-this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you!!
Jun 24, 2010 | Casio Exilim EX-Z1200 Digital Camera
Casio EX-S600 digital camera takes good photos, but the display is really ghosted with a very faded picture and vertical color bands through it. It worked fine earlier today and has not be dropped. Any...
Thank you!!
May 19, 2010 | Casio Exilim EX-S600 Digital Camera
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Jan 29, 2010 | Casio Exilim EX-S880 Digital Camera
I have casio exilim ex-z50. It worked fine the last time i used it. I went to use it yesterday and when i powered it on it asked for a date & time reset. after i reset the time it turned off and would...
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 07, 2009 | Casio Exilim EX-Z50 Digital Camera
The screen is black and blank on my casio exilim 10.0 mega pixals casio camera. I can take pictures. The memory card is working just fine
Are the pictures also black?
Is so the main circuit board in the camera is probably faulty. This is expensive to replace.
If the Pics are still good it could be the display has been turned to off or the lcd has been damaged and/or back light is not operating.
If you could give some answers to the above we might be able to norrow down you issue further. Please also advise exactly what model Casio you have.
Nov 13, 2008 | Casio Cameras
Black spot in display
If the camera operates normally and the only problem is no picture is visible on the lcd in record mode and playback mode,then the lcd needs to be replaced.
Jul 31, 2008 | Casio Exilim EXZ1050 Digital Camera
Casio exilim EX-Z75 BLACK COLOUR - UK/EUROPE
Go into the menu screen. There is a "reset" option.
Dec 18, 2007 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
Camera screen dark
It sounds like you broke the backlight on the display. I would contact Casio to find a repair center.
Feb 13, 2007 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-Z3 Displays turns off when taking a picture
I have the exact same problem. Casio wants the camera mailed in and charges $79 for a new LCD screen (if that is the problem). Any other suggestions?
Oct 14, 2006 | Casio Exilim EX-Z3 Digital Camera
Cameras Logo
26 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
