Question about AKG Perception 200 Microphone
Microphone cuts out
I have an AKG Perception 200 microphone. I use it in my band and for some reason the mic will cut out sometimes and i wont be able to get any output out of it. Other than that when it does decide to work its an awesome microphone. I have tried different chords and PA's but i always get the same problem.
    President:
  • 1,137 Answers
If you tried other cords and other PAs the problem might be in the jack where the cord plugs into the mike. service@akg.com might also be able to give you more info.
Posted on May 19, 2009
  • Michial Gueffroy May 19, 2009
    If you have tried different cords and PAs you can still try checking the jack on the mike where your cable plugs in. service@akg.com might also be able to help you.
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Oct 06, 2009 | AKG Perception 200 Microphone
My AKG Perception 200 Cut the signal suddenly
Sounds like a loose connection. Try duct taping the microphone cable in place where it enters the microphone.
Jul 27, 2009 | AKG Perception 200 Microphone
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Jun 08, 2007 | AKG Perception 100 Microphone
AKG Perception 200 Microphone Logo
340 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
