Question about Watches
Battery for compu chron classic - Watches
What size battery for this Watch?
Don't even bother. Just take it to your local jeweller who keep all the batteries in stock and will replace the battery for between $4 and $8. It is just not worth trying to find the battery and do it yourself.
Apr 28, 2016 | Armitron Looney Tunes Tweety watch...
Chron startstop button stuck
put a spot of WD40 down the sides of the button then try pull and pushing with tweezers
Mar 27, 2015 | Swatch Irony Chrono #YOS414G Watch for Men
What kind of battery does a victorinox officer's 1884 watch use
It might say on the back cover of the watch, if not, when you carfully pry the back of the watch off, you will see the battery, and it will say on the battery what it is.
Jan 02, 2013 | Victorinox Swiss Army Classic Officer 1884...
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
How to remove stem to get to battery in ebel ladies watch?
On my men's classic wave, the stem is removed simply by pulling it out. It feels like it's requiring a lot of force, but it is designed to have resistance so that it's not pulled out accidentally when setting the time.
So to change the battery, you remove the 5 faceplate screws, remove the crystal and gasket, pull out the stem and then the whole face/movement assembly will pull forward.
NOT positive yours is the same, but that's how my men's Classic Wave is. Good luck!
Dec 18, 2010 | Ebel Classic 1157111/0225 Wrist Watch
Zero in second hand
Easier than you think.Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Aug 29, 2010 | Invicta Subaqua Noma Iii S
I want to replace the battery in my wife's Ebel
After removing the 5 screws and the glass with seal, put your screw driver und the opposite edge to the winder. By carefull lifting,(do not force) you will find the inner watch assembly lifts out enough. to access the battery. The winder spindle has a joint in it which allows the body to bend on it to almost 90 degrees.
Hope this is helpfull
Aug 24, 2009 | Ebel Classic 1187141/0225 Wrist Watch
Changing a watch battery
I used a sharp penknife blade to remove the watch front by getting right on the base and pinching the glass off, (comes off quite easily) tilt the watch out of the case and see enough to prise battery out with a needle. The battery is a Maxwell SR920W or equivalent. Have ordered new batteries on ebay.
Oct 04, 2007 | Watches
Ebel Classic Wave fitting a new crown
i have changed the battery on my and my wifes ebel classic wave watch,,
step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
step 2 ...remove all 5 gold bezel screws
step 3... be careful,, the bezel/crystal will pry off easy
step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
step 5.. small screwdriver and remove/replace battery
step 6... reinstall watch guts/bezel and gold screws
step 7... push crown back into watch
step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
if have done it many times ,, you can do it !!!!
Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
Watches Logo
20 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
