Question about Fasco D701 Furnace Blower Motor 1/2HP 9.6 AMP
Motor will not spin
Recently replaced old GE motor in a trane xe80 with the d701. Motor will not spin up nor will it free spin.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Check input power.
Posted on Dec 30, 2013
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
I have a 5 yr old GE Harmony Dryer and it sometimes does not turn the drum. I'd say about 2/3's of the time it operates totally normally, but the other times the drum doesn't turn and you have to open the...
Unfortunately your motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are GE certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on doing it yourself, if you'd like.
The switch your talking about is a centrifugal switch inside the motor. Once the motor turns to a specific RPM, it makes and keeps the motor going until the timer turns it off or the door is opened. But it is the motor itself which starts the spinning. But the motor is not doing it's job so the C switch doesn't come into play.
Best, G
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
Why is my fan motor on my trane air conditioner running backwards when we turn the unit on. It is a trane a053bs.
Check the capacitor for the fan. Has the fan been replaced recently? If so make sure the start lead is connected to the capacitor.
Jun 19, 2010 | Goodman CKL24AR24 Air Conditioner
My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Mar 23, 2010 | Heating & Cooling
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
The pump motor seems to be jammed on my GE Model GSD2000j I was gone for a few months and it stuck on the 1st wash when I returned. The motor will not turn freely and is buzzing and heating up . Can I free...
Dishwasher motors are susceptible to getting stuck if not used regularly. Manually spin the motor to free it up. Dishwasher motors are not serviceable and must be replaced if found defective.But try to access the bushings/bearings and put a few drops of lubricant then spin it manually to free it up.
Aug 31, 2009 | GE GSD2000J Dishwasher
Trane XE1200 Fan Motor
Most likely problem with a not-so-old motor is the run capacitor for the fan.
Some units have fan & compressor capacitor combined into one -- others are separate.
The capacitor can be tested with a multi-meter with an MFD setting -- it should read reasonably close to the specs marked on the capacitor.
Charlie
Aug 19, 2009 | Heating & Cooling
GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Sep 18, 2007 | GE WWSE5240G
Fasco D701 Furnace Blower Motor 1/2HP 9.6 AMP Logo
102 people viewed this question
Top Fasco Heating & Cooling Experts
Oloyede Monsuru
Laurie Wookey
Level 1 Expert
Tom Chichester
Are you a Fasco Heating and Cooling Expert? Answer questions, earn points and help others
