Question about JVC GPS
How can i get a map update for kw-nt800hdt? - JVC GPS
I have a 1999 honda accord when i mash the gas it bogs down and at idel it speeds up and slows down by it self in park could my calantic converter be stoped up has no power going up a hill but runs good if...
is the check engine light on, keyon and goes out running
yes, its on running ! then scan it. do not skip this...
no need to guess at all, there are simple cheap test, for all failures
forget idle, idle is the lasting that will work with a ratty running engine.
Bogs, not misfire, (shakes for misfire) is lean burning.
if feels like your are pulling a 5000 trailer of lead.
a long hard smooth bog, not transitory.
im sure you did a tune up and sparks are not 15 years old. huh?
possible causes ( you never said what engine in car.? there are many)
1: low fuel pressure.
2: MAF is dirty (got a maf) or if a MAP EFI , the map vacuum cant reach the mAP, for clogging or it leaks reasons, (hoses?)
3: if MAF system , any air leaks will cause bogs.
called unmetered air, and air cant burn, the ECU must see all air
to add fuel correctly. (the 02 sensor corrects for small intake leaks)
id bet your 02 is not even on online at all. do to gross fueling issues.
this is the basics, good engine,good spark good fueling.
we do simple tests to find this.
if you want to test, say so and engine spec, and we can.
what engine, this fact tell me what EFI system you have.
and i can not fix cars with unknown EFI.
a short list. more world wide, why not say country.?
2.0L F20B5 I4 147 hp (110 kW)
2.3L F23A1 I4 150 hp (112 kW)
2.3L F23A4 I4 148 hp (110 kW)
2.3L F23A5 I4 135 hp (101 kW)
3.0L J30A1 V6 200 hp (150 kW)
the car is sold all over the world, where are you?
only 2 posts now in 6000 post told this BIG secret.... funny that.....
Feb 04, 2014 | 1999 Honda Accord
How to reset map update message on jvc nx7000
Here's the solution from the JVC Customer Service. BE WARNED: this will wipe out all your customizations, including but not limited to favorite addresses and radio station names.
"As for turning off the message about the maps on the radio, please follow the next steps.- Please follow this procedure to perform a factory reset and remove the message.
1. Turn ON the radio
2. Set the Source to "Tuner" mode
3. Simultaneously press and hold the [Disp], [Map] and [Down] buttons for more than 2 seconds
- You must press the buttons in that order
4. When the "Service Menu" Screen appears you may release the buttons
5. Touch the UP/DOWN arrows to highlight "Initialize All"
6. Touch [Enter] to initialize the unit
7. The unit will be initialized and the unit will reset on its own.
Apr 20, 2012 | JVC KW-NX7000 Car DVD Player
Problem with JVC KW-NX7000 Car bluetooth and gps messeage.
The bluetooth headset may not be compatible for the GPS reciever.. Check for the configurations for bluetooth.. and then install..
Apr 01, 2012 | JVC KW-NX7000 Car GPS Receiver
Upgrade maps on JVC KW-NT30HD
Necvox 9 tuning sound with car speaker problem.
Dec 16, 2011 | Car Audio & Video
My sansa fuze wont play i know it has power in it because the blue light surrounding the center dial is lit yet i cant get a screen to come up nor can i shut it off
Sandisk gives next support link, how to recover the player:
http://kb.sandisk.com/app/answers/detail/a_id/4/kw/blue%20ring/r_id/101834
Solution 1: RESET THE DEVICE
Scroll to the Sansa Fuze on next site, how to perform a reset:
http://kb.sandisk.com/app/answers/detail/a_id/188/kw/blue%20ring/r_id/101834
When solution 1 did not help.
Solution 2: RELOAD AND UPDATE THE LATEST FIRMWARE
All data on the player will be erased when updating firmware !
Go to next sites, seeing how to do a firmware update:
1. To perform a firmware update the player has to be in MSC mode.
How to put the player in MSC mode, see the information about the
Fuze player:
http://kb.sandisk.com/app/answers/detail/a_id/61/kw/blue%20ring/r_id/101834
Putting Sansa Fuze in MSC mode:
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the left button ( |<< ) while connecting the device to the PC.
2. Continuing with the firmware reinstallation you can choose either automatic or manual update, see:
http://kb.sandisk.com/app/answers/detail/a_id/278/kw/blue%20ring/r_id/101834
Automatic update using the Sansa Updater.
or
Manual update going to Sansa Forums.
Need more help ? Just post a comment.
Dec 10, 2009 | SanDisk Sansa Fuze MP3 Player
JVC KW-NT1 GPS not working in UK
Have you tried re-flashing the unit with the latest EU firmware update available from the JVC website? http://www.jvc-victor.co.jp/english/car/support/navi/nt1/eu/index.html Should overide the current firmware then allow you to use UK maps. If it doesn't work you can always reflash it with the USA update.
Nov 28, 2009 | JVC KW-NT1 Car GPS Receiver
KW-NW7000 "lost GPS signal"
New FW 1.3.4.0 is posted as of Sept 2009
Jun 27, 2009 | JVC KW-NX7000 Car DVD Player
Jvc kw-avx800 divx upgrade
go to ur settings. you will find a divx code. with that code you have to log on to the internet and sign up. with that code you enter it (following the instructions) then you will recieve the update, with that update it will ask you to save it to disc or removable storage device. once saved, plug it into ur jvx deck and it should update automatically.
Jul 18, 2008 | JVC KW-AVX800 CD Player
GPS Logo
Top JVC GPS Experts
Are you a JVC GPS Expert? Answer questions, earn points and help others
