Question about Audiovox Prestige Cl100 Carlink System
What is my passcode? - Audiovox Prestige Cl100 Carlink System
  • nitai pada saha
    nitai pada saha Dec 28, 2013
    Hi nitai pada saha, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Can I make a new password
Yes, you can
Use passcode with your iPhone iPad or iPod touch
Set your Passcode
    1)Go to settings > Touch ID & Passcode. On devices without Touch ID, go to Settings > Passcode.
    2)Tap turn passcode on
    3)Enter a 6-digit passcode
    4)Enter passcode again to confirm Change passcode or passcode settings
    To change your passcode or passcode settings, go to Settings. Touch ID and passcode. On devices without touch ID, go to settings > passcode.
Nov 19, 2015 | Cell Phones
I turn off my ipad passcode an it still comes on
Go to settings > passcode > turn passcode off ! At each stage you will be asked to enter passcode for security! After this is complete when you go to settings > passcode, you should see "turn passcode off"
Oct 22, 2014 | Apple iPad Tablets & eReaders
How do I delete the passcode on IPhone 5?
Try this:
1. Settings > General > Passcode
2. Enter your current passcode when prompted
The first option should be "Turn Passcode Off", if not scroll down to find it. You can also find other options for using your passcode.
Sep 23, 2014 | Apple iPhone 5
How do you reset passcode on ipod touch?
You will need to know the present Passcode to access your iPod Touch and change the Passcode.
1. Go to Settings
2. Go to General
3. Go to Passcode Lock
4. Select "Change Passcode"
5. Remember your new Passcode.
Jun 15, 2014 | Apple iPod touch
My IPad has been hacked into I need to. Know how to change my password.
With the push of a button and pull of a slider, you can quickly access all of your iPad's contents, including any sensitive personal data that you've stored within it.
Such easy and unrestricted accessibility to your device could be dangerous in the hands of a stranger, which is why you enable a password to block its use by anyone but you.
If you believe that your password's confidentiality has been compromised, don't fret. You can change it using your iPad's Passcode Lock feature.
Tap "Settings" on the home screen.
Tap "General" on the left sidebar.
Tap "Passcode Lock" on the main pane to the right.
Type your current four-digit passcode in the "Enter Passcode" screen that appears.
Tap "Change Passcode." Type your current four-digit passcode again in the first "Change Passcode" screen that appears.
Enter a new four-digit passcode in the second "Change Passcode" screen.
Retype your new four-digit passcode in the third "Change Passcode" screen.
This will simultaneously verify and activate your new passcode.
http://support.apple.com/kb/HT4113
iOS: Using passcodes
http://support.apple.com/kb/ht1212
iOS: Forgotten passcode or device disabled after entering wrong passcode
Jan 13, 2014 | Computers & Internet
Disable password on my ipad
First of all, to turn off or change settings for the passcode lock feature on your iPad you must know your passcode. If you have forgotten your iPad passcode you're out of luck.
To turn off passcode lock:
1. Navigate to Settings -> General -> Passcode Lock
2. Enter your passcode.
3. Touch the top button labeled Turn Passcode Off.
4. Enter your passcode again.
The passcode is now deactivated and will not be required to accessicon1.png your iPad.
Oct 02, 2013 | Computers & Internet
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    Acer Extensa 4630Z passcode for bluetooth
    Passcode is the temporary code for wireless devices when pairing with each other to establish a secure connection. You can assign any numbers or codes you like for the connection to take place. Suppose when you are asked to enter the passcode, enter 123 on the computer's passcode box and then same 123 on the cellphone. It'll automatically accept, but you need to assign the passcode everytime you connect the devices (as I've mentioned for once connection only).
    You can assign any numbers or letters as passcode, but it should be set the same code on both the devices.
    Good luck.
    Thanks for using FixYa.
    Jul 12, 2010 | Acer Computers & Internet
    Forgot my passcode
    Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
    Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
    Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
    If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
    Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
    Nov 10, 2009 | Apple iPhone 3G
    PASSCODE HOW DO I RESET THE PASSCODE?
    You cannot reset the passcode, however the default passcode is "0000"
    Jul 17, 2008 | Samsung WEP170 Wireless Headset
    Audiovox Prestige Cl100 Carlink System Logo
    13 people viewed this question
    Top Audiovox Car Audio & Video Experts
    xxxxxx xxx
    Jaime Hernandez
    Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
