Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connect mac to tv
Display settings
  • Sharp Master
  • 9,783 Answers
Use the HDMI cable input. Select the input number on the TV . If you can't do that then use a Hi def cable between the the Mac and the TV.
Posted on Dec 31, 2014
I have recently purchased a Panasonic TX-P50S21BA. I previously had a 42 inch older model. I used to display my apple computer on this tv using the hdmi adapter into my MAC. It doesnt appear to work on...
Have I understood correctly that when you select the HDMI input you can actually see the output of your mac? You can however only see PART of the desktop, In which case you need to configure the video output of the mac to match the resolution of the TV or vice versa or both. The old tv was probably a lower resolution 1368x720so the mac output fitted, the new tv is 1920 x1080.
On your TV, go to Menu>Settings>Screen>Display Mode and then select Full Pixel or whatever turns overscan off if there is such an option and/or on the mac set your display settings on the display port. (don't know what mac it is but it's in system preferences or apple, displays) and change the resolution on the display port till you find one that works the best, theoretically 1920x1080, but many people find other settings work better, depends on the TV/adapter etc.Eventually you will find a combination that works OK!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Panasonic Televison & Video
When I connect my unibody macbook pro to my old tv using a vga to tv converter, my computer doesn't even recognize the disyplay.
When you connect your tv to your mac, make sure the cables are plugged into the TV first, and then plug your mac into the computer.
But a vga to tv converted doesn't make much sense. Your connection should be mini-display from your mac, to an adapter to either VGA, DVI, or HDMI depending on your TV connection type.
Dec 31, 2010 | Apple Computers & Internet
I've connected my macbook pro with a DVI-D to HDMI adapter cable. The autosource briefly detects my computer, then gives a "no signal" indicator. Meanwhile, my computer detects the display, but I have no...
It sounds like there is a conflict in the display types. the tv and the mac must be set to the same type of signal and display type. for example, your mac is set to output at 1080x640, but the tv is set to 720x480. They have to match or they will conflict each other
May 07, 2010 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Trouble connecting Insignia HDTV 19" to my macbook pro
One of the first things you may notice about your new big-screen HDTV is that it has more connections for video than your old TV ever dreamed about. It probably has two or three HDMI connections, maybe a DVI connector, a VGA connector, and at least one component video connection. And those are just the connections most commonly used for high definition.
It’s shame to let all those connections go to waste. Your Mac just happens to be sitting nearby; why not hook it up to your new HDTV? It's actually a pretty easy task. A few lucky souls won't even need an adapter; for the rest of us, at least one adapter will be necessary.
Pick the Right HDTV PortFor best quality, your HDTV's HDMI or DVI ports are the preferred connection method. Both are capable of the same digital quality. The only practical differences are the style of the connector and the fact that HDMI supports video and audio in a single connection.If it has one, another option is to use your HDTV’s VGA port. The VGA connection isn't as good as the HDMI or DVI method, but as long as your TV supports full resolution via the VGA port, you'll be hard pressed to notice the difference.Mac Pro, MacBook Pro, Mac MiniMac Pros, MacBook Pros, and Mac Minis have standard DVI connectors. Mac Minis and MacBook Pros have a single DVI port; Mac Pros have at least two DVI ports.If your HDTV has a free DVI port, then all you need is a standard DVD cable; no adapter is necessary. But in all likelihood, you'll need to connect your Mac to your HDTV using either an HDMI or VGA connection; both options require an adapter. If you choose VGA, you can use the adapter that came with your Mac.If you choose HDMI, you'll need a simple adapter, which is available from multiple sources. The adapter may be a cable with a DVI connector on one end and an HDMI connector on the other, or it may be a small adapter that has both types of connectors, but no cable. Either type will work fine.iMac, MacBookiMacs and MacBooks have a mini DVI connector for hooking up external monitors or TVs. You'll need at least one adapter, maybe even two. At a minimum, you'll need a mini DVI-to-DVI adapter. You may also need a DVI-to-HDMI or DVI-to-VGA adapter, depending on which port on the HDTV you choose for the connection.Make the ConnectionOnce you determine which, if any, adapters you need, and have the necessary cable to reach from your Mac to the HDTV, turn off both the HDTV and the Mac. Connect the cable between the Mac and the HDTV.Turn the HDTV back on first. It doesn't need to be set to the connection the Mac is on, but it must be powered up first, so that when it boots, your Mac can recognize the TV and the resolution it needs. Once the HDTV is powered up, turn on the Mac.Your Mac should recognize the format and resolution of the TV, and automatically select the native resolution of the TV for running the video. In a few seconds, you should see the Mac desktop on the HDTV.Over or UnderscanYou may notice that the Mac's desktop appears to be slightly larger than the HDTV's screen (its edges are cut off); this is called overscan. Or, you may notice that the desktop doesn't occupy all of the HDTV's screen real estate (there are dark areas around the edges); this is called underscan.You can usually correct either issue by making adjustments on the HDTV. Check the HDTV's manual for information on making scan-related adjustments. They may be called overscan, underscan, dot-by-dot, or pixel-by-pixel. If your HDTV has a dot-by-dot or pixel-by-pixel capability, give this a try; it should eliminate any over or underscan issues. Some HDTVs only offer these special scan controls on specific inputs, so be sure to connect to the corresponding input on your HDTV.Time to Watch a MovieOnce you have your Mac and HDTV working together, it's time to kick back and watch a video from your Mac. Be sure to check out the QuickTime HD trailers for a sense of what HD and your Mac is capable of. Enjoy!
Feb 22, 2010 | Insignia 19 in. Widescreen Flat-Panel LCD...
I want to use my lcd tv as a monitor for my NEC VERSA E6200.How do i set this up. I have already connected the cords and then turned in the tv and laptop and this hasnt worked. Please help Eddie
When you are on the desktop screen, Right click your mouse, Display properties will open. click on settings. Now click advanced. Then click displays.
Most chances are that you will see 3 options. Monitor, Panel and TV. click on TV. Click ok. Check whether your TV is getting connected. Once this is working properly, come back and on the scheme, you can select "Switch amongst displays" click Ok . Hope this helps.
Jan 30, 2010 | Computers & Internet
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Jul 13, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Toshiba 27A250 S-Video Recognized by Mac But Not Viewable on TV
Is your TV NTSC or PAL
and does your Mac have a video output setting box ?
make sure your mac is putting out the correct video standard
and try another Y\C 'S-Video Cable'
Jun 16, 2009 | Televison & Video
TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
Apr 08, 2009 | Westinghouse Televison & Video
I am trying to re-connect a Mac Mini DVI output to an old (original model) Gateway42" plasma TELEVISION. The problem is I re-set the display on the Mac Mini to a widescreen resolution, which the TV will...
Unplug both from power , and remove mac battery, restart first mac then TV, already connected.
Check source with tv remote, and ensure mac res is correct.
Mar 28, 2009 | Televison & Video
Laptop
You gotta go to system preferences and click on display then click on detect display settings. its should work. if not press F7 after clicked on detect displays
Nov 06, 2008 | Computers & Internet
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
48 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
