Question about Kenmore 63942 Dryer
Timer running but nothing happens 70 series
You can hear timer running but when u push the start button nothing happens
    President:
  • 1,136 Answers
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. THis is the most common problem.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Posted on May 18, 2009
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
I have a Kenmore 70 series. About 10 years old. The inside light comes one, the timer ticks when turned but nothing happens when I push the start button. We have already checked the breaker. Is there...
you either have a blown thermostat, blown thermal fuse, or a bad heating element most likely a blown thermostat
email me if you need more help in replacing or testing
Nov 16, 2010 | Kenmore 73952 Gas Dryer
When I push the start button on my Kenmore 700 series dryer nothing happens. You can hear the timer clicking as if it is getting power, but the dryer doesn't come on. Could this be a defective timer?
Check the door saftey switch and the start button for continuety.
My bet is the door switch.
Then look at the timer if both those are good.
Mar 19, 2010 | Dryers
Our old Kenmore Model:65801 quit working. You can hear the timer running but nothing happens when you push the start button.
Try pushing the door switch in with your finger while trying to start. If works, see if the door fits tightly and the hinges are not worn out. Another trick is glue something to the door where the switch strikes so that the button is pushed further.
Sep 14, 2009 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Kenmore series 70 mod#110.62722100
check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Jan 25, 2008 | Dryers
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Kenmore 63942 Dryer Logo
88 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
