Question about Home Meridian Comfort Lift Recliner
Up button on remote inop.
May need remote how where to order
    Sergeant:
  • 264 Answers
Try Home Meridian...........
Posted on Nov 05, 2014
Heater controls stop working and rear defrost inop and the park assit not working and we tried to program a keyless entry remote that didnt work eathier tried that and everything stop working
Did you check fuse's in fuse block center console ? Fuse #26 IGN3 / HVAC 10amp . Do you know what I'm talking about ?
Fuse Block - Center Console
Inside of console, behind the right console access panel
What did you do jump terminals in the DLC ?
You need a factory scan tool to program keyless entry remote .
  1. Install a scan tool.
  2. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
  3. Press the START soft key on the scan tool.
  4. Important: The scan tool must stay connected until all of the transmitters are programmed.
  5. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
  6. Repeat the previous step in order to program up to 4 transmitters.
  7. Remove the scan tool.
  8. Operate the transmitter functions in order to verify correct system operation.
Oct 09, 2016 | 2004 Buick Rendezvous
Hyundai ImageQuest HQL320WR Remote Control Issue
You can buy a replacement remote, I will post the link here.
Oct 26, 2008 | Hyundai ImageQuest HQL320WR 32 in....
Remote partially inoperative
When only one button on a remote fails, most likely the unit is damaged or contaminated - best bet is replacement. And don't eat or drink around the remote. And remember nothing lasts forever anyway.
Aug 18, 2014 | Sylvania Televison & Video
Trunk release wnen key, remote and button are inoperative
The fob is probably dead, needs a battery...if your doors dont lock with fob that would confirm this, and I believe there is also a fuse for the door button...will work when car on but not when off is a blown fuse I think.
Feb 08, 2014 | 1997 Saab 900
The go video remote doesn't work only here and there
you can check it is transmitting. hold it up to the camera on your phone and press buttons. you will see the infrared led in the front glow white on the screen. (this test to find dirty /inoperative buttons). Hint you should only need to press buttons hard enough to make them nove to the bottom of their travel - any harder and they need cleaning.
Then try using the remote closer to the machine. if it work better when closer to the machine then replace the batteries - weak batteries ONLY affects RANGE
Mar 16, 2010 | GoVideo Go Video DVD/VCR Combo
95 S10 blazer 4dr power door locks inop, new battery installed in remote, all fuses good, still inop?
1. Locate the red two wired programming connector located near the central locking control module that is located behind LH Lower instrument panel. Drop the panel and you will see the red programming connector that is not connected to anything.
2. Inside the Red programming connector you will see to pins..
Jump two pins with a section of wire.
3. System should now lock and unlock doors to indicate vehicle has entered programming mode.
4. Press any button on keyless remote once. System should now lock and unlock doors indicating the keyless remote has been programmed.
5. Repeat step 4 to program other remote.
6. Remove jumper wire from programming connector to exit programming mode.
7. Test Remote(s)
Dec 22, 2009 | 1995 Chevrolet Blazer
Volumn inop,remote inop
sounds like the vol down button has stuck try agitating it ..good luck farr64
Apr 29, 2009 | Symphonic ST420FF 20" TV
Hooked to computer says buttons temporarily inoperative
The frame is supposed to say that. It just means you have given up control of your frame to your computer. When you disconnect the frame from the computer, you can use the remote control again.
Jan 16, 2009 | SmartParts SPX8 Digital Picture Frame
Menu settings control inoperative.
I have the same projector and after I thought it is faulty, I finally solved the problem by putting a signal on the input. With out the signal the unit will only switch the bulb on and the menu wont be available.
Hope this help
Nov 21, 2007 | Acer PD116 Multimedia Projector
Home Meridian Comfort Lift Recliner Logo
130 people viewed this question
Top Home Meridian Furniture Experts
Tom Chichester
Lawrence Oravetz
Are you a Home Meridian Furniture Expert? Answer questions, earn points and help others
