Question about Panasonic Televison & Video
Panasonic blu-ray disc sa-btt775 has no picture
Lost picture when man set up foxtel box. Have tried new HDMI cable with no luck. Am running HDMI ARC out to HDMI in television with optical cable for sound. Get sound but no picture.
  • 146 Answers
SOURCE: Distorted audio on my surround sound
If it does it with just the one disc it is probably the file that you burned. Does the file sound ok on the computer? Sometimes files that are downloaded have bad audio tracks and I have seen cases where the encoding software that you are using messes up the file when it is modifying the file.
Try another DVD or Blu-Ray disc and see if it still distorts. If it does then it may be a setting in the player or in the receiver.
Cheers
Posted on Jan 01, 2009
SOURCE: Incompatible Disc in Sharp BD-HP21X Blu-Ray Disc Player
I had the exact same problem as you did... I bought the Sharp Aquos 42D85X which came with Sharp BD-HP21X Blu-ray Disc player. could not get brand new blu-ray movies to play and i found it froze everytime after 10 secs. I phoned sharp who basically were no help watsoever! I then went and returned my blu-ray movies back to the store thinking it was a problem with the discs.. The people there were extremely nice and since they had a display model of the BD-HP21X instore they offered to test the movie on it to veroify whether it was the blu-ray player was the problem or not. Turns out its a fault with all of the BD-HP21X models. So we then ended up returning it back to the store we bought it and exchanged it with the older model (BD-HP20X). I now have no problems playing blu-ray movies. Although another suggestion is to perhaps download the lastest firmware update & see if that resolves your issues.
Posted on Mar 16, 2009
  • 6 Answers
SOURCE: My HDMI cable wont work from my new Blu-Ray player
On the blu- ray player you have to set it to HDMI in the options or else it wont work
Posted on Oct 24, 2009
  • 53 Answers
SOURCE: How to connect Panasonic BD60 Blu-ray disc player to 2 components
If there are red and white RCA jacks on the back of the BR player and on the receiver you should be able to get sound. The same as your VHS.
Posted on Dec 29, 2009
SOURCE: Just purchased a new samsung blu ray player with
onkyo receivers have a problem, see
http://www.hdtvsupply.com/hdmi-cable-booster.html
Posted on Jul 06, 2010
No HDMI video using RX-V575 Yamaha Receiver with Panasonic TV C-P60ST30
Michael, I still think it is a connection problem. Try disconnecting the HDMI and see if you get the video. If no, it is a connection problem. Check the connections carefully.
Mar 24, 2014 | Yamaha RX-V575
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
Panasonic sa-bt207 blu ray player. Connected with AOC Full HD TV with HDMI cable. Picture quality perfectly displayd, however, no sound.
Hi, having a blue ray myself connected via HDMI, I'm inclined to think it may be a setting in the blue ray's menu under audio since audio signal is usually provided by HDMI. I hope this was helpful as I was unable to find anything online regarding your model. Thank you for asking FixYa and don't forget to comment back please. Good luck-Prodzilla
Apr 24, 2011 | Audio Players & Recorders
I have a Panasonic Plasma TH 42PV500A and have now set up with a Panasonic Blu Ray disc recorder DMR BW850. They are linked by a HDMI cable. I can turn Plasma on and off, change volume etc via new Blu Ray...
the link system is only availible with certain equipment at this time. The exernal devices have to have the proper set up in them to allow this to work,
Apr 27, 2010 | Panasonic Televison & Video
My samsung bd-p1500 blu-ray player won't play blu-ray discs on regular ones... was having all sorts of troubles with it finally updated the firmware and now it won't play any blu-ray discs
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
Apr 01, 2010 | Samsung BD-P1500 Blu-Ray Player
Hello, We have a new bravia w series lcd tv. We have connected it to our dvd and foxtel digital box. We can get dvd and foxtel sound but no foxtel picture. I believe that the connections to the foxtel and...
Hi Michelle,
Does the Foxtel have a slot in the back marked HDMI Out? If so, this is the best possible connection to the Bravia. However you would need to pick up the HDMI cable (like bestbuy) It is a video & sound all in one. Do the 6 cords end in RCA jacks, and are they color coded?
Read Ya,
Z
Dec 31, 2009 | Insignia IS-PDVD10 Portable DVD Player
My panasonic blu ray wont play space odyssey 2001 the tv says mode not supported, it plays the sound but no picture all other blu ray discs play as normal. Can you help?
I did solve the puzzle what I did was to, disconnect the HDMI cable and reconnected via component video and it worked well. I am still not sure why it wouldn't play with HDMI as all my other blu ray discs played OK.The TV is a Samsung 52in lcd.
Oct 27, 2009 | Panasonic DMP-BD30K Blu-Ray Player
Oct 24, 2009 | Samsung BD-P4600 Blu-Ray Player
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Televison & Video Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
