Lg 32 inch 32lk310
Left half of screen opague white
  • 395 Answers
SOURCE: My screen Half Black - Half Red
you have a warranty! the set has a problem either with the panel or the main board take it back to the store where you bought it and exchange it or have it repaired by a factory authorized repair place.
Posted on Mar 02, 2008
toolkits
  • 1099 Answers
SOURCE: Looking for LG 32LH4000 32-inch sky+ remote
Well first you can try - 065, 244, 405, 318, 037, 398, 191, 459, 245, 389, 060, 275, 0206, 0584, 0742, 0851, 1165, 1176, 1208, 1219, 1280, 1293, 1665
if none of the code works for you then please follow the below link to know how to search your sky remote code -
sky.com/portal/site/skycom/skyhelpcentre/producthelp
also check the below link
skyuser.co.uk/tools/remotecodes/index.php
Good Luck!!
Posted on May 29, 2010
  • 115 Answers
SOURCE: Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Posted on Jul 31, 2010
taran_2005
  • 10515 Answers
SOURCE: my 32 inch lcd tvs
Disconnect the power supply for few minutes, say 30 minutes and then ON the TV. If the problem still persists, this would confirm a hardware failure and needs repair.This would need you to open the unit and repair it. If you have electronics repair experience, could read schematics, would be able to keep precautions, revert and i would tell you few pointers. You would also need to have the service manual of the TV. Moreover, you need to be ready with multimeter and soldering iron. Kindly answer below questions as well so that i could help you to repair it :-
1. Make and model of the TV?
2. How old the unit is?
3. Does the 3 lines remain stationery or not?
4. Do you have sound?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 23, 2010
dduncan774
  • 760 Answers
SOURCE: Element HDMI 32 inch. Left
One of 2 things happened here. Either your T-con board is defective and needs changed, or your Panel is defective and you need a new TV.
Posted on Apr 11, 2011
LG 32LC2R 32 inch Wasworking ok, now blinks 5 times
Seems like you have an Inverter issue
Inverter board is under the psu to the left and its job is to
light the lcd panel so you can see the picture
give me more info and i might help you to fix this
Aug 17, 2014 | LG 32LC2R 32 in. HD-Ready LCD Television
Why rgb connection o.k. NO TV signal?
Check your manual for instructions to select video source. Also , please be aware that rgb video also usually requires separate audio connections along with the rgb.
Jun 08, 2014 | LG 32LK310 LCD HDTV, 32 Display Size, 16:9...
Lg 47lh40
Check its connection between LCD pane and T'con board for any loose contact.
Apr 28, 2013 | LG 47LH40 47 in. LCD HDTV
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Left half of screen dimmer than right
same issue with my 47le5900 - I have fixed it... if I look through the back panel I can see a circuit board on the right... coming out of this at the top are two flat data cables, each about 1 1/2 inches wide, one is labeled (L) the other (R), it seems the (R) one was a little loose, so I pressed it downwards with a small screwdriver, problem solved.
Jun 25, 2012 | LG 42LE5500 42 in. TV
I have 2 lines across the screen that are blank (no color) on the left side of the screen there is a figure can fix this myself?
you either need to reset the lvds cable, or you have a bad panel. if it's the panel, it's trash.
Nov 02, 2010 | LG 32LH30 32 in. LCD HDTV
My tv stopped showing picture but still apperears
If the whole screen is just white light, the the LCD controller (t-con) board may have gone out. Your TV can have more than one version of the boards inside.
You can get parts here: http://www.shopjimmy.com/catalogsearch/result/?q=LG+32LG30+
Dec 09, 2009 | LG 32LG30 32 in. LCD HDTV
Only the left half works
You could try removing the ribbon cable directly under where the lines are from the X module and clean the cable and reinsert it. You could have a bad X Module if cleaning doesn't fix it.
Let me know if this helps.
Jul 29, 2008 | LG 32LX1D 32 in. LCD Television
Mar 02, 2008 | LG 32LC7D Television
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
