Question about managemylife.com
Replace gas and fuel lines
How to replace gas and fuel lines gas leaf blower vac model 358798980
    Genius:
  • 1,049 Answers
Ryobi instruction manuals
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
Poulan blower fuel lines
I would guess the fuel line you installed is kinked somewhere.
Jan 12, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Oct 12, 2012 | Craftsman Garden
I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Nov 02, 2010 | Homelite Garden
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Fuel lines dry and brittle how to replace on craftman 24cc gas powered blower vac
take one of the lines to a hardware store and see if they have the proper size. You should be able to change them easily. Just remember to clamp the ends to prevent gas from leaking out.
Jun 15, 2009 | Toro Blowers Rake and Vac - Electric...
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
managemylife.com Logo
27 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
