Question about General Electric WCSR2090D Top Load Washer
Won't drain need diagram for washer
Need diagrams for ge washer model number wcsr2090d2ww
    Problem Solver:
  • 4 Answers
If you need to know the diagram is found in control panel .Check for voltage to pump also make sure a sock is not stuck in pump .
Posted on May 30, 2009
100 series clothes washer not spinning
I don't see a question but you may find help at the link below.
If you need to buy parts or diagrams try searspartsdirect.com
Have your model number ready.
maytag washer won spin YouTube
Jul 24, 2014 | Maytag Clothes Washer Door Lock Switch...
Wssh300g2ww won't drain
Tip this on its side and look from underneath. You should be able to see better what is holding it on there. Every washer is different and everyone makes you swear when working on it.
Jan 31, 2013 | GE WSXH208A Front Load Washer
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
Water won't drain on the wash or rinse cycle
Hi.
If the machine does not drain the parts to be tested are rain system, motor and control board must also be tested. If machine is a top loader testing will start from lid switch. The first action will consist in checking the drain hose at the back and checking the drain filter accessible from lower front side of your GE WSXH208A.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 14, 2011 | GE WSXH208A Front Load Washer
I have a top loading Kenmore series 80 washer. The cycle starts, agitates, but won't drain and go into a spin mode. It just stops after the agitate is done and remain full of water. It won't...
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 12, 2011 | Kenmore 24032\24036 Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
May 25, 2011 | General Electric WSSH300G Front Load...
I need a diagram electric washer machine GE mod S3700G0WW
go to www.sears.com and then click the parts direct link up top... type in your model number and on the right side it will ask is this part number or model click model. it will search and come up with your model if you have the correct one... should show you a diagram and parts break down...
good luck to you
Jan 06, 2011 | Washing Machines
My GE front loading washer model #wssh300goww
Your drain is most likely clogged.
The timer runs out, and the water has not completely drained.
Just before the pump, there is a screen cup that needs to be disassembled and cleared of debris. Many times small articles of clothing or coins can block up the passage.
CLICK HERE for all the blowout diagrams of your washer.
THIS ONE - of the tub and motor - specifically - shows the filter cup (part #340) circled.
This is a common design flaw in front load washers - and easily remodied.
If you require further clarification about your question... please use the "Continue With This Expert" option so we are connected in the future.
Thank You for using FixYa!!
Apr 29, 2009 | GE WSXH208A Front Load Washer
Cracked discharge hose on GE washer
Are you sure thats the model number? Im having trouble finding it on my end???
Dec 17, 2007 | Washing Machines
General Electric WCSR2090D Top Load Washer Logo
482 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
