Question about Vehicle Parts & Accessories
2005 pt cruser door panel removal
Need to unlock back driver side door to reconnect crossbar
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 62 Answers
This might help some.
Posted on Apr 02, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a 2004 PT Cruiser and having a problem with the back drivers side manual locking mechinism. The door will not unlock. I am wondering if you would tell me how to remove the inside door panel with not...
u can try to remove the rear seat...this may give u the room u need to pull the door panel off...if not u may try a service station an have them use a lock pick set to unlock the door
Jul 14, 2011 | Chrysler PT Cruiser Cars & Trucks
Driver's side power window was inop. Window failed to go back up. Chevy dealer replaced the regulator motor and now working. Now the power dood lock switch on drivers side won't unlock doors.. Is the...
Hi, that wire is disconnected when the door panel is removed to work on the window motor. Take the car back and ask them to reconnect your door locks. If you want to fix it yourself, you may be able to access the connector by removing only the control panel where the door lock switch is installed. Remove any visible screws and then pry gently to pull up the panel. Odds are, however, that the whole door panel will need to be pulled loose to find the cable. You can possibly just pull the bottom of the panel loose, but do it carefully. Feed the wire back up to the control panel and reconnect to the switch. Thanks for using Fixya.
Jan 24, 2011 | 2003 Chevrolet Venture Passanger
My 2005 PT Crusier driver side windows won't work, front and back...passenger side both fine.??????
This sounds like the window motor is bad, try holding the switch in the up or down postion and bang on the inside of the door panel and if the window moves then you will know its the motor, the motor is the most common problem but testing would be nice to make sure, you would need to remove the door panel and with a test light test at the connector that plugs into motor,
Jan 03, 2011 | 2005 Chrysler PT Cruiser
I have a 2005 Hyundai Elantra when trying to lock or unlock doors from either the remote or drivers side master switch passenger side doors will work, but drivers side doors front or back will not lock or...
door lock actuator might be faulty or bad electrical contact
take off the door panel and diconnect and reconnect the wiring, you might need to change door lock actuator
Dec 26, 2017 | Hyundai Elantra Cars & Trucks
When the battery was unplugged from the car and then reconnected, the passenger side windows will not roll up or down on 2005 pt, I was told there is a reset button but do not know where. It cost a lot...
if the passenger windows work from the drivers side switch then the anti trap window mechanism need recalibrating.you need to hold the passenger switch on the drivers door switch pack down till it gets to the bottom and then hold the switch down for ten seconds then send it up when it gets to the top hold the switch in the up position for ten seconds repeat this for all other windows.if this fails try disconnecting your battery again.
Apr 26, 2010 | 2005 Chrysler PT Cruiser
Power windows -window falls inside the door, won't go up
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Pull back the weather seal and you should see the cause.
It could be the window has fallen off it's base (not likely), a cable has disconnected or broken (most likely), motor burned out (maybe)
Sep 23, 2009 | 2005 Chrysler PT Cruiser
2005 Honda Odyssey front doors won't lock/unlock with panel buton
try just replaceing the drivers actuator first....that should take care of it
Mar 28, 2009 | 2005 Honda Odyssey
How do I remove the inside door panel on drivers side
you need to take out the door panal and work from the inside of the panal. Open it from there.
Jan 11, 2009 | 2001 Mercury Grand Marquis
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
