Question about Dishwashers
My dishwasher is westinghouse SB916, how do I replace the element to heat the water
4 Suggested Answers
  • 185 Answers
SOURCE: How to replace heating elemant on Zanussi DE6850 Dishwasher
is your water heater set on 120 degres
Posted on Mar 31, 2008
SOURCE: Dishlex DX302SB Dishwasher water not
Who posted this comment I am really appreciative. I have had the same problem with my dishlex. I disassembled the plumbing and removed a chunk of plastic wrapping from inside the pump. Then I checked the heater with a multimeter. It measured fine.
The next day I read this post and have since removed the controller. I found the burnt solder joint mentioned. I have since cleaned up the mess, repaired the circuit board, re-soldered the effected component and the dishwasher is now working better than ever.
I have read elsewhere that this problem arises when the door is opened while the heater is on and the program hasn't been paused. I don't know if that is the exact cause but in my house we will be more careful about that from now on.
The damage to the circuit board was on the Normally Open terminal of the relay used to control the heater. The heater is marked as being about 2100 watts. The relay is marked as being able to switch 125Vac. Which is interesting because power here in Australia is 240Vac. At 240Vac the heater will draw a little under 10 amps when operating.
Anyway the circuit board trace is possibly a little narrow at the point where the burnt connection was and I can see why it would have burnt out. The other terminals on the relay were showing signs of becoming dry joints too. The repair was effected by completely removing the relay, cleaning all the joints, re-soldering the relay and laying a loop of tinned solid wire around the burnt terminal to replace the missing piece of circuit trace.
Anyone who has a little skill with a soldering iron could perform this repair. The worst that could happen is you could lift what is left of the circuit trace from the board. Since the controller is already broken you can have a go and probably save yourself the cost of a new controller.
Posted on Apr 08, 2009
  • 74 Answers
SOURCE: my dishwasher doesn't heat the
if the thermostat is bad that's where your problem is and nothing else
Posted on Nov 18, 2010
Westinghouse sb916
check hot water supply. Is the valve open?
Aug 07, 2013 | Dishwashers
I have a Westinghouse SB915SJ*00 dishwasher. It runs right through a cycle but does not heat. Any suggestions? Thanks.
Hello
The majority of dishwashers are not connected to hot water from the mains but heat up the water internally using the heating element, located in the tub of the dishwasher, controlled by a thermostat. When the dishwasher has a fault with heating, the program will run but not complete and will show an error code on the display panel. Dishes won't be cleaned properly and the detergent won't dissolve.
If your dishwasher does bring in hot water externally from the mains to check the water is warm and there are no problems with the inlet. If the dishwasher heats internally then it is most likely a faulty heating element or thermostat. A fault like this will usually require a replacement part and a repair, but you can check the heating element with a voltmeter to ensure that it is the cause of the problem before calling out for a service engineer.
Sep 10, 2011 | Dishwashers
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon
Sep 07, 2011 | Westinghouse Dishwashers
My dishes come out clean but wet. They used to always come out dry. Do I need a service or replacement part? I have a Westinghouse touchdry SB915.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2011 | Westinghouse Dishwashers
Does the dishwasher model GDB742RJS0 have a heating element or does it require a cold and hot water hook up thanks
Yes, your dishwasher has a heating element. You only need a hot water hook up. attached is a picture of some of the parts in your dishwasher. The heating element is #1. It is located at the bottom.
Hope this clear things up.
Please vote and add any comments you wish.
Mr Tin Man
Dec 21, 2010 | Westinghouse Microwave Ovens
No heatinh - Westinghouse SB925SJ*00 - suspect dual water sensor (Water presence and temperature). Require price and availability. Thanks.
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 30, 2010 | Westinghouse Dishwashers
I have a Westinghouse Dishwasher. The water will not heat. what could be the problem
It's very possible that your heating element has gone out on this unit.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your complete model number and we will be happy to get the correct element, along with part removal/installation instructions for you to repair this problem.
We answer our phones from 7 AM until 9 PM CST so call us when you are ready! Thanks, Ella
Nov 13, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Dishwashers Logo
187 people viewed this question
Top Dishwashers Experts
