Question about Pentair Minimax NT Heater
The heater ignites then after a few seconds it shuts off then continues to ignite and shut off
Heater ignites then goes on and off
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 44 Answers
Stack flue sensor or ignitor
Posted on Dec 11, 2014
  • 246 Answers
SOURCE: jandy lite2 heater
t problem is not at the ignator but t flame rectification need ignator kit and flame rectification kit
Posted on Sep 18, 2009
  • 246 Answers
SOURCE: Minimax 250 Cycling on and off after reaching 20 degrees
change the assembly valve
Posted on Oct 13, 2009
  • 990 Answers
SOURCE: I have a 250K mimimx nt heater that has been
This is a fan code. If your fan is running then the air pressure switch has a problem. On some units the gas pressure switch is on the same circut. This would be the NT LN model. On this one gheck to be sure your gas is on and bled out first. If this is a LP heater be sure you have enough gas to run it. Most heaters need at least 30% on the tank to get enough pressure to run the heater. If it is the air pressure than you need to check your air flow. Be sure to check you don't have bird or rat nests in your exaust or on the burner tray assembly. If you don't have any of these problems you may need a new air sensor. I hope I have helped.
Posted on Dec 20, 2009
  • 44 Answers
SOURCE: my wife said the pump timed off and the heater was
The fan will continue to run for a few minutes after the pump turns off to purge exhaust gasses.If it was still heating you have a problem. To reset the heater,turn off the pump breaker for 30 seconds. After that you need a repairman.
Posted on Sep 28, 2010
SOURCE: master temp 400 with E05 error message, already replaced stack flue sensor, thermistor, and igniter. Any suggestions?
I have had the same problem with my '400' since it was new. I contacted the manufacturer and got the run around. I have been trying to get this resolved and now, a year and a half later, have decided to buy a different heater. Anyone want to buy a hardly used Pentair 400? sandtrap699@yahoo.com
Posted on Sep 23, 2013
Ignition control failure
Try cleaning the flame sencor first , or it could be the snap dice shutting down there are two on there you could bridge them out one at atime and see if it stays on .
Nov 22, 2012 | Mr. Heater Natural Gas Garage Heater -...
My Rheem Ruud 25M01A water heater flame goes out before the thermostat is satisfied. The igniter goes into a ignition sequence from here on trying to get the flame to ignite for ever. If i turn the unit...
Check the air lines going to air pressure switch for cracks or splits. I know that will affect the gas valve but not sure if that is your problem.
May 07, 2010 | Heating & Cooling
Heaters runs for a few minutes then shuts off.
was working fine refilled it and now it will run 5sec. and kick the breaker on it.It's an old 80's model 35,000 B.T.U. I cleand the photo eye with a cloth no change. Any solution's
Jan 29, 2010 | Reddy Heater-30-55,000 BTU Variable
My reddy heater R50,(50,000btu)when started will
the unit is working exactly as designed , the system is noticing that the unit has not fired so it shuts down so there is not a lot of unburnt fuel everywhere.
try to find out why the unit is not igniting . is the igniter sparking continually
Nov 12, 2009 | Tools & Hardware - Others
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
The heater will not ignite properly
How old is the thermostat? Also there a limit switches at different points on that unit. If you have a volt ohm meter find the round disc like safety's and ohm them out. Take the wires off the disc before testing them. You should have a continuity should be closed they only open if unit gets too hot. Say something like 180 degree's.
A fast way to check out the thermostat is take a small diameter wire take the cover off the t-stat and jump across the R and the W on the t-stat. If the furnace comes on then t-stat bad. Let me know if this is helpfull. Ken
Nov 09, 2008 | Cozy (W352E) Heater
The heater will not ignite properly and the heater will not shut off
Judging by your pics (helpful, by the way) you have a high limit wired into your thermostat wire. Try disconnecting that wire nut connection in front of your valve and hooking the thermostat straight to the top and bottom posts on the valve (eliminating the high limit). If it runs fine, either the connection was poor or your high limit wire is pinched.
Feb 28, 2008 | Cozy (W352E) Heater
Pentair Minimax NT Heater Logo
214 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
